syntax question
Posted: 06 Jun 2020, 15:39
by Sasch600xt
Hello all
i have an 3 way switch and try to do something like this, but it wont work
sure the problem is me
if the switch is in position "up" i want to switch MCPGPIO,1,1 (works already)
if the switch is in middle position i want MCPGPIO,1,0 (does not work)
if the switch is in position "down" i want MCGPIO,1,StateOfmcp#29 (does not work)
on mcp#18=1 do // Switch position "up"
MCPGPIO,1,1
on mcp#18=0 do // Switch position "middle"
if mcp#17=0 // to make sure Switch is not in position "down"
MCPGPIO,1,0
on mcp#17=1 do // Switch is in Position "down"
if mcp#29=1 do
MCPGPIO,1,1
MCPGPIO,1,0
would be great to get some help here
Thank you very much !!
Have a great day
Re: syntax question
Posted: 06 Jun 2020, 15:53
by grovkillen
Do you have monitor activated for them?
Re: syntax question
Posted: 06 Jun 2020, 16:06
by Sasch600xt
yes, monitor is activated for all MCP inputs.
Re: syntax question
Posted: 06 Jun 2020, 17:06
Just a simple question.
Are you sure this is ever entered?
Maybe add a logentry statement in that block, to make sure it is detected as being 'low'.
Also I'm missing a "do" here:
and an "endon" for this block:
Re: syntax question
Posted: 06 Jun 2020, 17:41
by Sasch600xt
thank you
i changed it to:
on mcp#18=1 do
MCPGPIO,1,1
on mcp#18=0 do
if mcp#17=0 do
MCPGPIO,1,0
on mcp#17=1 do
if mcp#29=1 do
MCPGPIO,1,1
MCPGPIO,1,0
"Maybe add a logentry statement in that block, to make sure it is detected as being 'low'."
Could you show me exactley what it means ? How could it look like ?
And you are right, at the moment it looks like it does not detect "low"
This one here:
on mcp#17=1 do
if mcp#29=1 do
MCPGPIO,1,1
MCPGPIO,1,0
is not working, mcp#17 is high and mcp#29 is high, but MCPGPIO,1 is low.
will the trigger work only in the first run, or will this be triggered as long i have mcp#17 high in every loop ?
Thank you for your help
Re: syntax question
Posted: 06 Jun 2020, 19:30
by Ath
You need to add [ and ] around the variable(s) in the 'if' lines, (but not in the 'on' lines).
Re: syntax question
Posted: 06 Jun 2020, 20:18
by Sasch600xt
ok, thank you
i have it now like this:
on mcp#18=1 do
MCPGPIO,1,1
on mcp#18=0 do
if [mcp#17]=0 do
MCPGPIO,1,0
on mcp#17=1 do
if [mcp#29]=1 do
MCPGPIO,1,1
MCPGPIO,1,0
but still only the first block is working.
second block does not switch MCPGPIO "low"
and third block does MCPGPIO,1 "low" even when mcp#29 is "high"
still my question would be:
for example in the third block, let´s say MCP#17=1 but mcp#29 is low.
will the rules check on every loop for mcp#29 for "high" or "low" or just once when mcp#17 is "high" the first time and then never again untill mcp#17 is "low" and "high" after.
Thank you all so much for help
Re: syntax question
Posted: 06 Jun 2020, 20:25
by Ath
Hm, the if doesn't have a do, it's just the if and a condition/test, you might want to read the documentation on that again:
https://espeasy.readthedocs.io/en/lates ... Rules.html
Re: syntax question
Posted: 06 Jun 2020, 20:28
Maybe something like this:
on mcp#18 do
LogEntry,"MCP 18: [mcp#18], MCP 17: [mcp#17]"
if [mcp#18]=0
if [mcp#17]=0
MCPGPIO,1,0
MCPGPIO,1,1
on mcp#17=1 do
if [mcp#29]=1 // Is this correct, to compare with mcp#29 ????
MCPGPIO,1,1
MCPGPIO,1,0
As mentioned the if doesn't have "do".
I was mistaken by the fact there was one line in the given example that had an if ... do.
And usually some omission is more likely than something extra.
And I always ask GrovKillen for rules, as those are also not my cup of tea
Re: syntax question
Posted: 06 Jun 2020, 20:53
by Sasch600xt
thank you for helping
i did try TDer´s code but this was also no luck.
Maybe i try to explain what i want to do with the code:
the ESP is in my Car.
I try to control my extended rear lights.
i have a switch with 3 Positions:
Pos "up" = mcp#18 HIGH
Pos "middle" = mcp#18 AND mcp#17 LOW
Pos "down" = mcp#17 HIGH
Relay for Rearlight is MCPGPIO#1
Input for reverse gear is mcp#29 (HIGH = reverse gear selected)
So the 3 Positions of the switch should provide this features:
Position "up" = rearlights ON
Position "middle" = rearlights OFF
Position "down" = rearlights only ON if reverse gear is selected, else OFF (automode, here the rules should check always about i have reverse gear IN or not)
Thank you so much
Re: syntax question
Posted: 06 Jun 2020, 22:18
Maybe you should leave that last part out first.
So only trigger on the mcp#18 and not the 17.
Re: syntax question
Posted: 06 Jun 2020, 23:34
by Sasch600xt
ok, this i did for now:
on mcp#18 do
if [mcp#18]=0
if [mcp#17]=0
MCPGPIO,2,0
MCPGPIO,2,1
i can switch it ON, but not OFF
Re: syntax question
Posted: 06 Jun 2020, 23:52
Well maybe Grovkillen or ThomasB can have some new insight in the rules here.
I'm a bit too tired right now to think clearly.
Re: syntax question
Posted: 06 Jun 2020, 23:58
by Sasch600xt
same here
i try again tomorrow.
But thanks alot for all your help already !
good night
Re: syntax question
Posted: 07 Jun 2020, 00:47
Good night to you to
Re: syntax question
Posted: 07 Jun 2020, 11:26
by Sasch600xt
Good morning all
So maybe today we get it to work
I am so sorry that it turns out more complicated then i thought
Happy Sunday
Re: syntax question
Posted: 07 Jun 2020, 12:32
I summoned the Rules Jedi master.
Re: syntax question
Posted: 07 Jun 2020, 12:57
by grovkillen
The thing is that you probably have both 18 and 17 change at the same time, thus I'm not sure what state your rule is triggering. I would test this:
on mcp#18 do
Event,triggering=[MCP#18],[MCP#17],[MCP#29]
on mcp#17 do
on triggering do
if %eventvalue1%=1
MCPGPIO,1,1
if %eventvalue1%=0 AND %eventvalue2%=0
MCPGPIO,1,0
if %eventvalue2%=1 AND %eventvalue3%=1
MCPGPIO,1,0
if %eventvalue2%=1 AND %eventvalue3%=0
MCPGPIO,1,1
Re: syntax question
Posted: 07 Jun 2020, 13:14
by Sasch600xt
Thank you for your help.
with the new code nothing is working, not ON, not OFF and not depending on state of mcp#29.
monitoring is avtivated for all mcp channels.
but the code looks wonderful and exactley what i need
Re: syntax question
Posted: 07 Jun 2020, 13:29
by grovkillen
Could you look into the log when you have this rule triggered? And add the event values to log entry just to see if they are correct.
Re: syntax question
Posted: 07 Jun 2020, 13:37
by Sasch600xt
i hope i know how to do so
i found a little mistake in the code and changed it already :
on mcp#18 do
on mcp#17 do
on triggering do
if %eventvalue1%=1
MCPGPIO,1,1
MCPGPIO,1,0
MCPGPIO,1,1 // In this case i need the relay ON
MCPGPIO,1,0 // in this case i need it OFF
how do i have to change the code to provide more information in the log ?
Thank you so much for your help !
Re: syntax question
Posted: 07 Jun 2020, 13:41
by Sasch600xt
this is the log:
39423: EVENT: Clock#Time=Sun,13:39
63979: WD : Uptime 1 ConnectFailures 0 FreeMem 20552 WiFiStatus 3
74572: EVENT: MCP#18=1
74593: ACT : Event,triggering=,,
74594: Command: Event
74594: EVENT: triggering=,,
77172: EVENT: MCP#18=0
77193: ACT : Event,triggering=,,
77194: Command: Event
77194: EVENT: triggering=,,
78972: EVENT: MCP#17=1
78995: ACT : Event,triggering=,,
78996: Command: Event
78997: EVENT: triggering=,,
83974: EVENT: MCP#29=1
88174: EVENT: MCP#29=0
91972: EVENT: MCP#17=0
91995: ACT : Event,triggering=,,
91996: Command: Event
91996: EVENT: triggering=,,
93979: WD : Uptime 2 ConnectFailures 0 FreeMem 18728 WiFiStatus 3
99423: EVENT: Clock#Time=Sun,13:40
123979: WD : Uptime 2 ConnectFailures 0 FreeMem 19928 WiFiStatus 3
Re: syntax question
Posted: 07 Jun 2020, 14:04
by Ath
To me it is at least 'strange' that the event is fired without any values, only the commas, do you have a screenshot of your Devices page, showing the MCP settings?
Re: syntax question
Posted: 07 Jun 2020, 14:09
by Sasch600xt
to be honest i do NOT have the MCPs in devicepage.
because there are 16 outputs and 16 inputs.
How can i handle that in devicepage for 12 devices ?
Re: syntax question
Posted: 07 Jun 2020, 14:11
by Sasch600xt
this is how my rules look like at the sysboot:
on System#Boot do
monitor,mcp,1
monitor,mcp,2
monitor,mcp,3
monitor,mcp,4
monitor,mcp,5
monitor,mcp,6
monitor,mcp,7
monitor,mcp,8
monitor,mcp,9
monitor,mcp,10
monitor,mcp,11
monitor,mcp,12
monitor,mcp,13
monitor,mcp,14
monitor,mcp,15
monitor,mcp,16
monitor,mcp,17
monitor,mcp,18
monitor,mcp,19
monitor,mcp,20
monitor,mcp,21
monitor,mcp,22
monitor,mcp,23
monitor,mcp,24
monitor,mcp,25
monitor,mcp,26
monitor,mcp,27
monitor,mcp,28
monitor,mcp,29
monitor,mcp,30
monitor,mcp,31
monitor,mcp,32
Re: syntax question
Posted: 07 Jun 2020, 14:28
by Ath
Not sure if then the [MCP#n] variables can be used? AFAICS that's not possible, as [var#name] is referring to Device names and variables.
We could use the 16 custom variables for that, something like this:
on mcp#18 do
let 1,%eventvalue%
Event,triggering=%v1%,%v2%,%v3%
on mcp#17 do
let 2,%eventvalue%
on mcp#29 do
let 3,%eventvalue%
Event,triggering=%v1%,%v2%,%v3% // trigger needed on mcp 29 too?
on triggering do
if %eventvalue1%=1
MCPGPIO,1,1
MCPGPIO,1,0
When in need of more than 12 Devices, grab an ESP32, that can have up to 32 Devices
Edit: You may need to initialize the variables at boot.
Re: syntax question
Posted: 07 Jun 2020, 14:32
by grovkillen
Yep, since you're not using device/task those square brackets are referring to something that isn't existing. Ath's approach is the one to go.
Re: syntax question
Posted: 07 Jun 2020, 14:52
by Sasch600xt
YAY !!!
It works PERFECT with the internal sys variables !
@grovkillen:
Thank you so much for your patience and great code
@Ath:
also thanks for your patience and help.
you where right, mcp#29 had also to be reconized. (this is when i put the reverse gear in)
I LOVE the ESP32
But i made a lot of PCBs for the ESP8266
So if i have time (hahahahahaha) i have to redesign my PCBs for the ESP32 and order some in china.
So for all, who run into the same problem, here is the finally working code:
on System#Boot do
monitor,mcp,17
monitor,mcp,18
monitor,mcp,29
on mcp#18 do
let 1,%eventvalue%
on mcp#17 do
let 2,%eventvalue%
on mcp#29 do
let 3,%eventvalue%
on triggering do
if %eventvalue1%=1
MCPGPIO,1,1
MCPGPIO,1,0
MCPGPIO,1,1
MCPGPIO,1,0
Thank you all for your help and i wish you a great Sunday
