I have already flashed several ESP80266 with ESP EASY Mega.
Last chip used : ESP01 with Vesion : mega-20200426
In the log files, I regularly find the following error:
WD: Uptime 1485 ConnectFailures 0 FreeMem 21376 WiFiStatus 3
The value Uptime and FreMem change.
All My ESPs are configured with a fixed IP.
One example:
Client IP filtering
Client IP block level: Allow local subnet
Access IP lower range: 192.168.90.0
Access IP upper range: 192.168.90.255
IP Settings
ESP IP: 192.168.90.77
ESP GW: 192.168.90.1
ESP Subnetmask: 255.255.255.0
ESP DNS: 192.168.90.1
Every thing work well but I don't understand this message?
Otto
WD : Uptime 1473 ConnectFailures 0 FreeMem 21768 WiFiStatus 3
Re: WD : Uptime 1473 ConnectFailures 0 FreeMem 21768 WiFiStatus 3
WD is short for WatchDog, the 'mechanism' that hits the brake (reset) if it doesn't get a sign of activity of the software, indication of a 'hung' system.
The message is just a regular update for 'the rest of the world' to let them know all is fine, and includes some interesting technical numbers.
Indeed, it is for sure not an error, but more like status information shown every 30 seconds.
Uptime in minutes (so 1473 is little over a day), no connection failures recently to reach some other hosts in the network, close to 22k of free RAM (which is quite a lot actually) and WiFiStatus 3 is "connected" if memory serves me well. (have to check in the code, newer builds show an actual string)
Many thanks for your informations.
Otto
Otto
