Functions in rules. For example, ABS.
Andrew Mamohin
#1 Post by Andrew Mamohin » 22 Sep 2020, 13:55
I need an ABS function in the rules. I need to execute a block based on the difference between two temperatures (regardless of which direction) How can you do this?
Andy.
Re: Functions in rules. For example, ABS.
#2 Post by TD-er » 22 Sep 2020, 16:37
Right now we don't have an abs call, but you could store the result in a variable and simply check to see if it is negative.
If it is negative you can multiply its value by -1.
Or just check the 2 values you want to subtract.
If A > B do A-B else B-A.
Andrew Mamohin
#3 Post by Andrew Mamohin » 22 Sep 2020, 17:57
TD-er wrote: 22 Sep 2020, 16:37 Right now we don't have an abs call
Well, it's ass-backwards! :)
Thanks for the help, I did:
on T_1#T do
 if [T_1#T] > [T_2#T]
  TaskValueSet 12,3,[T_1#T]-[T_2#T]
  TaskValueSet 12,3,[T_2#T]-[T_1#T]
on T_2#T do
How can I do it in one block? There are no subroutines in the rules.
Andy.
Micha_he
#4 Post by Micha_he » 22 Sep 2020, 17:58
or...
[Device#Value]^2^.5
for ABS.
Andrew Mamohin
#5 Post by Andrew Mamohin » 22 Sep 2020, 18:09
Micha_he wrote: 22 Sep 2020, 17:58 [Device#Value]^2^.5
Wow! It's beautiful!
Andy.
#6 Post by Ath » 22 Sep 2020, 21:19
Andrew Mamohin wrote: 22 Sep 2020, 17:57 How can I do it in one block? There are no subroutines in the rules.
User defined events are the substitute for subroutines:
on T_1#T do
  event,CalcAbsDiff
on T_2#T do
  event,CalcAbsDiff
on CalcAbsDiff do
Edit: Fixed typo
Andrew Mamohin
#7 Post by Andrew Mamohin » 23 Sep 2020, 08:02
Ath wrote: 22 Sep 2020, 21:19 User defined events are the substitute for subroutines:
Thank! I did this.
You got a typo:
on T_2#T do
event,CalcAbsDiff
enddo
need endon
Andy.
