Stack overflow at chained events in irrigation-control-rules
Micha_he
#1 Post by Micha_he » 23 Sep 2020, 16:49
I've a problem with my rules of my irrigation control (beta/develop-state).
The event-rule 'VentilSchalten' (without the current comments) switch my valves on or off. The event-commands like 'Event,VentilSchalten=1,1' works as I expect.
The event-rule 'AutoPrgStartStop' should start the program 1-3 (Task 9 Value 1), with different segment-sequences (Task 9 Value 2). Tested, seems to work like I planned.
The event-rule 'AutoPrgWeiter' should switch to the next segment. Test looks good.
But If the event 'AutoPrgWeiter' trigger the event 'VentilSchalten' with the two needed parameters (e.g. VertilSchalten=1,1) and the event 'VentilSchalten' has all source code activated, the ESP reboot with a reason 'Software Watchdog'. But it work, If I comment all and do only a Let with the two eventvalues.
Can someone have a look to it ? Maybe a problem with the stack of the eventvalues ? In a simple test nested event-rules work at least to deep to three event-rules.
Here is the device-configuration:
rules1.txt:
on System#Boot do
  PcfGpio,1,0  // Ventil1
  PcfGpio,2,0  // Ventil2
  PcfGpio,3,0  // Ventil3
  PcfGpio,4,0  // Ventil4
  PcfGpio,5,0  // Ventil5
  PcfGpio,6,0  // Ventil6
  Gpio,13,0    // Relais 12V Versorgung
  if [Zeiten1#Dauer1]=0
    TaskValueSet,7,1,15
  if [Zeiten1#Dauer2]=0
    TaskValueSet,7,2,10
  if [Zeiten1#Dauer3]=0
    TaskValueSet,7,3,15
  if [Zeiten1#Dauer4]=0
    TaskValueSet,7,4,10
  if [Zeiten2#Dauer5]=0
    TaskValueSet,8,1,10
  if [Zeiten2#Dauer6]=0
    TaskValueSet,8,2,8
  if [Zeiten2#Anpassung]=0
    TaskValueSet,8,3,1
on MQTT#Connected do
  Event,Statusabfrage
on Statusabfrage do
  Publish,/%sysname%/status/LWT,Connected
  Publish,/%sysname%/Ventil1/Status,[Ventil1#Status]
  Publish,/%sysname%/Ventil2/Status,[Ventil2#Status]
  Publish,/%sysname%/Ventil3/Status,[Ventil3#Status]
  Publish,/%sysname%/Ventil4/Status,[Ventil4#Status]
  Publish,/%sysname%/Ventil5/Status,[Ventil5#Status]
  Publish,/%sysname%/Ventil6/Status,[Ventil6#Status]
ruels2.txt:
on VentilSchalten do
  Let,%eventvalue1%,%eventvalue2%
  // Event,PumpeUndNT=%eventvalue2%
  PcfGpio,%eventvalue1%,%eventvalue2%
  // if %eventvalue1%>0 and %eventvalue1%<5
  //   Let,7,[Zeiten1#Dauer%eventvalue1%]*[Zeiten2#Anpassung]*60
  // endif
  // if %eventvalue1%>4 and %eventvalue1%<7
  //   Let,7,[Zeiten2#Dauer%eventvalue1%]*[Zeiten2#Anpassung]*60
  // endif
  // if %eventvalue2%=1
  //   Timerset,%eventvalue1%,[INT#7]
  // else
  //   Timerset,%eventvalue1%,0
  //   Let,7,0
  // endif
on Rules#Timer do
  if %eventvalue%<7
    Let,%eventvalue%,0
    Let,7,0
    PcfGpio,%eventvalue%,0
    Event,AutoPrgWeiter
    Event,PumpeUndNT=0
on PumpeUndNT do
  if %eventvalue1%=1
    Publish,/SW011/cmd,"event,Schalten=1"
    Gpio,13,1
    if [VAR#1]=0 and [VAR#2]=0 and [VAR#3]=0 and [VAR#4]=0 and [VAR#5]=0 and [VAR#6]=0
      Publish,/SW011/cmd,"event,Schalten=0"
      Gpio,13,0
rules3.txt
on AutoPrgStartStop do
  if %eventvalue1%<=0 and [Programm#lfdPrg]>0
    if [VAR#8]<>0
      TaskValueSet,8,3,[VAR#8] // Wiederherstellung alte Anpassung
      Let,8,0
    TaskValueSet,9,1,0
    if %eventvalue2%>0 and %eventvalue2%<=1
      TaskValueSet,8,3,%eventvalue2%
    Event,AutoPrgWeiter
      if [Zeiten2#Anpassung]<>%eventvalue2%
        Let,8,[Zeiten2#Anpassung] // für Wiederherstellung merken
    if %eventvalue1%>0
      if [Programm#lfdPrg]<>%eventvalue1%
        TaskValueSet,9,1,%eventvalue1%
        Event,AutoPrgWeiter
      if [Programm#lfdPrg]<>1
        TaskValueSet,9,1,1
        Event,AutoPrgWeiter
on AutoPrgWeiter do
  if [Programm#lfdPrg]=0
    if [Programm#aktSeg]<>0
      Event,VentilSchalten=[Programm#aktSeg],0
      LogEntry,"Ventil [Programm#aktSeg] geschlossen"
      TaskValueSet,9,2,0
    LogEntry,"Programm gestoppt"
    if [Programm#lfdPrg]=1
      Let,9,[Programm#aktSeg]+1
    if [Programm#lfdPrg]=2 or [Programm#lfdPrg]=3
      if [Programm#aktSeg]=0
        Let,9,1
        Let,9,[Programm#aktSeg]+2
      if [Programm#lfdPrg]=3 and [INT#9]=7
        Let,9,[INT#9]-1
    if [INT#9]>6
      TaskValueSet,9,1,0
      Event,AutoPrgWeiter
      TaskValueSet,9,2,[INT#9]
      Event,VentilSchalten=[INT#9],1
      LogEntry,"Programm [Programm#lfdPrg]/Ventil [Programm#aktSeg] geöffnet"
    Let,9,0
Re: Rule-help with irrigation control
#2 Post by Ath » 23 Sep 2020, 19:12
The event handler PumpeUndNT has an if construction with too many conditions, a maximum of 3 conditions is supported. You'll have to break that up.
And you can't use arithmetic in those conditions (that would have been a simple fix).
If's can go up to 10 levels deep, so it is still quite easy to fix 8-)
Micha_he
#3 Post by Micha_he » 23 Sep 2020, 19:56
But that if-construct works for month, without that I recognize any problems.
And in my tests, the event 'PumpeUndNT' is commented out (Line2 in event 'VentilSchalten').
Thanks, that you take a look in it.
#4 Post by Ath » 23 Sep 2020, 20:16
Have you tried enabling all lines, except event,PumpeUndNT=%eventvalue2% in the VentilSchalten event handler? Those if's seem quite harmless, so I wouldn't expect it to crash.
There is also the ASyncEvent command, analog to the Event command, except it puts the event in the queue for processing, instead of calling it immediately (according to documentation, I didn't actually investigate this in the source), that could be worth a try.
The rules look like they should still work as intended when not being processed fully sequentially.
I've been experimenting with ASyncEvent too, as I also have a setup where events are triggered from events, and that has shown some instability (but not restarts, only event-storms), but that may also be caused by triggering events from another ESP unit...
Micha_he
#5 Post by Micha_he » 23 Sep 2020, 20:42
Ath wrote: 23 Sep 2020, 20:16 Have you tried enabling all lines, except event,PumpeUndNT=%eventvalue2% in the VentilSchalten event handler?
When I habe only active the first (Let) Line, the event works. If I enable the third (same with second) line, the ESP reboots while the execution.
But I'll do a test and reduce the if-condition and report here...
Edit: No difference with changed if-condition !
#6 Post by Ath » 23 Sep 2020, 21:35
Hmm, weird, one possibility could be that there are non-printable characters in your rules file, that won't show in the web editor. You'll need a proper editor (preferably Notepad++, View/Show Symbol/Show All Characters, but VS Code should be able to do that too), that can show non-printable characters, and all unexpected control-characters need to be removed.
It may also be advisable to check if the line ends used are Cr/Lf (Windows line ends), not Lf-only or Cr-only (Linux line ends or Mac line ends), as that may also cause unexpected trouble.
Ah, now I see this:
I don't think that will work as expected, and may very well be the cause of the exceptions, you'll have to have separate statements for each Dauer1 to Dauer6
#7 Post by TD-er » 23 Sep 2020, 22:10
I guess this is indeed the culprit:
I don't even have a clue what it would be when it is acually being parsed.
The order in which things will be replaced does matter here.
So it is very well possible this was once working if the %eventvalue% would be converted into some int which would match a variable name (e.g. "Dauer1")
Micha_he
#8 Post by Micha_he » 23 Sep 2020, 22:17
This line work flawlessly so far. (And is also commented out in the test).
You can reduce the event-rule to:
  PcfGpio,1,0
The reboot still happens.
No, non-pritable character and only windows-crlf.
Here are the rules as zip-package with reduced (mininmal) VentilSchalten-event-rule:
rules.zip
(1.3 KiB) Downloaded 285 times
Edit: And, the same rules (with original 'VentilSchalten') works, if I startet it via 'Event, VentilSchalten=1,1' under the webinterface/tools/command !
The problem exists only, if the event is executed via the event-rule 'AutoPrgWeiter' (Line 3,10,31) :(
#9 Post by TD-er » 23 Sep 2020, 22:53
I'm currently to that sharp anymore as I would like to be, so I leave the checking for matching on...endon and if...endif to those that are.
Can you show some info on the used memory?
Especially the free stack.
I suspect you're running out of memory via a stack overflow.
Can you try to replace the Event commands with AsyncEvent ?
There is also something fishy here:
on AutoPrgWeiter do
    if [INT#9]>6
      TaskValueSet,9,1,0
      Event,AutoPrgWeiter
As you can see, this can cause an infinite loop (or recursion, which is also bad for the stack)
Micha_he
#10 Post by Micha_he » 23 Sep 2020, 22:54
I'll try to reduce the test-environment to the needed dummy-device and the rules to a minimum tomorrow. Maybe that will help...
#11 Post by TD-er » 23 Sep 2020, 22:55
Pleae see my edit too.
Micha_he
#12 Post by Micha_he » 23 Sep 2020, 23:10
@TD-er: How I can be show the memory infos, before or until the reboot?
Micha_he
#13 Post by Micha_he » 23 Sep 2020, 23:30
TD-er wrote: 23 Sep 2020, 22:53
on AutoPrgWeiter do
    if [INT#9]>6
      TaskValueSet,9,1,0
      Event,AutoPrgWeiter
No, the reloop is only executed once. At least it should...
In my tests I've disabled it, to rule it out as the problem. When I reduce the rules tommorow, I delete this part.
#14 Post by TD-er » 23 Sep 2020, 23:44
Micha_he wrote: 23 Sep 2020, 23:10 @TD-er: How I can be show the memory infos, before or until the reboot?
That's hard, but I guess it may also run very low on memory when you do not yet crash and reboot.
So make sure you have the timingstats stuff enabled (not running the "testing" build) and then you can also see the lowest recorded free stack and heap values, including the function that was active at this lowest point.
When memory resources are suspect, you may also want to run with as few included plugins and controllers in your build as possible as those also use some memory even when not selected and enabled.
Micha_he
#15 Post by Micha_he » 24 Sep 2020, 17:31
I've reduce the environment for some tests.
Factory reset, single PCF8574-device, simple test-rule, no ntp, no MQTT-controller.
on Test1 do
  Event,Test2
on Test2 do
  Event,Test3
on Test3 do
  Pcfgpio,1,[Ventil1#Status#!Z]
Result: The roboot doesn't happen as often anymore, but after 2-25 execution of the command 'Event,Test1' via the tools-webpage, the reboot is done again !
Memory after reboot:
Memory after 20 event-executions without watchdog-reboot:
No more idea's... I'll change the ESP-WROOM02 to a ESP-12F and do another test.
#16 Post by TD-er » 24 Sep 2020, 17:45
Are the MQTT messages sent to the broker?
Or are they all placed in a queue?
Micha_he
#17 Post by Micha_he » 24 Sep 2020, 18:16
As long as I enabled the MQTT-Controller, the messages are sent faultless.
Edit: Found a difference. Now the reboot-reason isn't hardware-watchdog !?
#18 Post by TD-er » 24 Sep 2020, 18:28
That looks like it power cycled.
Micha_he
#19 Post by Micha_he » 24 Sep 2020, 18:32
After re-enable the openHAB-controller again, the ESP rebooted after 3 event-commands and the reason is 'Hardware Watchdog' again.
Edit: Now ~20 event-commands later, nothing has changed, the next reboot. Reason 'Software/System restart' ???
I'll try another ESP...
#20 Post by TD-er » 24 Sep 2020, 18:57
If it is crashing on HW watchdog too, then it could very well be a bug or a configuration issue.
Does it reconnect quite often to the MQTT broker?
Does it help if you continously send a ping to the node?
And can you post all of the rules you're now running?
And I don't see the build version mentioned.
Micha_he
#21 Post by Micha_he » 24 Sep 2020, 19:04
No, it doesn't reconnect often to the MQTT broker.
All original rules are in post #1 of this thread. Last test-rule is in post #15.
Build is 'ESP_Easy_mega_20200913_normal_WROOM02_2M256.bin' from Github-release.
Ping... I've not tested, because no disconnections. Maybe a later idea.
Micha_he
#22 Post by Micha_he » 25 Sep 2020, 09:36
Last test before I switch to the ESP-12F: No MQTT-disconnections while the last 13 hours. Thats not the reason.
Edit1: Changed to ESP-12F: Same problem :cry: tested with the simple rule from post #15)
Edit2: Custom-build with minimal plugin's didn't change anything.
Micha_he
#23 Post by Micha_he » 16 Oct 2020, 18:50
New minimal setup:
ESP (WROOM02_2M256, but ESP12F is the same) flashed with the latest firmware. Config is DHCP, NTP with fritz.box and one device PCFGPIO-switch-input (Port 1, slow I2C speed, name=Ventil1, valuename=status). I mean, thats all.
One rule:
on System#Boot do
  pcfgpio,1,0
on Test1 do
  Event,Test2
on Test2 do
  Event,Test3
on Test3 do
First I switch multiple with PCFGPIO-command, all is ok.
Ok.zip
(1.18 KiB) Downloaded 247 times
Now I use the event Test1 via tools/command: Event,Test1. The reboot ist done! Always. Here's the log with the exception-data:
Error_with_Event.zip
(15.54 KiB) Downloaded 234 times
The error can reproduce even without an existing PCF8574-device on the I2C-bus!
Help :cry:
Micha_he
#24 Post by Micha_he » 18 Oct 2020, 10:38
Can I do some addional test to find the problem?
Can someone else reproduce the problem?
Micha_he
#25 Post by Micha_he » 18 Oct 2020, 11:25
New insights:
The problem isn't dependent on the plugin 'Switch input - PCF8574' !!!
You can replace the only PCF8574-device with a simple switch input (e.g. name=switch, valuename=state, GPIO=12) and replace the second last line of the rule with 'GPIO,12,[Switch#State#!Z]'.
Event Test2 & Test3 works and event Test1 creates the exception.
#26 Post by TD-er » 18 Oct 2020, 20:51
Micha_he wrote: 18 Oct 2020, 11:25 [...]
That's causing a chain of events, so I guess you're creating a stack overflow there.
Is it really needed to have the events handled immediately?
If not, please call asyncevent instead of event, so the event will be queued.
This will make sure the rules parsing will not become recursive and thus use more stack.
See https://espeasy.readthedocs.io/en/lates ... nt-command
Using asyncevent will immediately return and place the event in a queue.
So you have to keep that in mind when writing the rules.
This implies the (async) event is not yet handled if you process the next command.
Micha_he
#27 Post by Micha_he » 18 Oct 2020, 22:09
Maybe I can use AsyncEvent in the rules AS workaround. I'll look...
But how can one device and 12 lines (9 lines with the 3 events) create a stack overflow?
Is it possible, that the events are started too quickly after each other?
Micha_he
#28 Post by Micha_he » 18 Oct 2020, 23:57
In my test-environment from the post above, the event-chain works, if I added a timer from 1s between the events.
It seems, that's the event-init or -execution is overlapping!
#29 Post by TD-er » 19 Oct 2020, 00:34
Micha_he wrote: 18 Oct 2020, 22:09 Maybe I can use AsyncEvent in the rules AS workaround. I'll look...
Well we only have 4k stack in total on the ESP.
And the rules parsing does allocate quite a lot. So when you call an event from the rules, you essentially create a new rules parsing call. That one fires an event, so a new rules parsing instance. etc.
So they are not started too quickly, but are handled IMMEDIATELY.
That's exactly the reason I suggest to use the asyncevent as that one does schedule the event instead of processing it immediately.
Micha_he
#30 Post by Micha_he » 19 Oct 2020, 07:58
But, when these events not executed too quick or the start didn't overlap, then that means, that 3 events being processed at the same time, cause the stack to overflow. :(
But if you think that this is not a bug in the parser, then I must switch to the AsyncEvent's... if It's possible in my irrigation-rules :?:
Re: Stack overflow at chained events in irrigation-control-rules
#31 Post by TD-er » 19 Oct 2020, 15:24
Well I do think it is undesired behavior for the unit to crash. So that crashing part is a bug.
But on the other hand, performing recursion via events in the rules processing is something you should try to avoid as we simply don't have a lot of resources on the ESP.
Micha_he
#32 Post by Micha_he » 19 Oct 2020, 18:00
I've changed all events to async and it's working without crashes.
Users browsing this forum: Google [Bot] and 31 guests
