Sonoff Relay, UDP SendTo, and Wifi interference
mrh_icb
#1 Post by mrh_icb » 09 Oct 2020, 04:54
I ran into an interesting issue, when trying to use Global Sync / ESPEasy P2P to network several Sonoff BASIC relays.
It seems that RF interference is caused by the Sonoff relay, which causes UDP packets dopped over Wifi. I thought I report my finding, in case anybody runs into it.
I used 2 Sonoff BASIC R2 relays, with an external switch on GPIO-14 each. Operating the switch on either unit shall flip the relay on both.
I enabled Global Sync / P2P on both, and assigned unit number 1 and 2.
First the non-working code, the sendto command never worked. It seems the UDP send gets disturbed by the local relay operating on GPIO-12.
on switch#state do
  if [relay#state]=1
    gpio,12,0 // turn off local relay
    sendto,1,gpio,12,0 // turn off remote relay
    gpio,12,1 // turn on local relay
    sendto,1,gpio,12,1 // turn on remote relay
After lots debugging, the solution was to simply switch the order of commands:
on switch#state do
  if [relay#state]=1
    sendto,1,gpio,12,0
    gpio,12,0
    sendto,1,gpio,12,1
    gpio,12,1
Re: Sonoff Relay, UDP SendTo, and Wifi interference
#2 Post by Ath » 09 Oct 2020, 07:41
Does this also happen when switching another gpio? For example gpio 2, instead of 12.
#3 Post by TD-er » 09 Oct 2020, 09:03
To me it looks like the extra power drawn from the relay may make the WiFi a bit unstable.
Can you at least also try with enabling sending Gratuitous ARP to see if it changes behavior?
Users browsing this forum: No registered users and 86 guests
