While the build-process the following errror is displayed:
Compiling .pio\build\normal_ESP8266_4M1M\lib3c0\Adafruit BusIO\Adafruit_I2CDevice.cpp.o
.pio\libdeps\normal_ESP8266_4M1M\Adafruit GFX Library\Adafruit_GFX.cpp: In member function 'void GFXcanvas1::drawFastRawHLine(int16_t, int16_t, int16_t, uint16_t)':
.pio\libdeps\normal_ESP8266_4M1M\Adafruit GFX Library\Adafruit_GFX.cpp:2070:30: warning: comparison between signed and unsigned integer expressions
[-Wsign-compare]
for (int8_t i = 0; i < lastByteBits; i++) {
.pio\libdeps\normal_ESP8266_4M1M\Adafruit GFX Library\Adafruit_GFX.cpp: In member function 'void GFXcanvas16::drawFastRawHLine(int16_t, int16_t, int16_t, uint16_t)':
.pio\libdeps\normal_ESP8266_4M1M\Adafruit GFX Library\Adafruit_GFX.cpp:2620:53: warning: comparison between signed and unsigned integer expressions
[-Wsign-compare]
for (int16_t i = buffer_index; i < buffer_index + w; i++) {
