Compile error with 4M1M with latest source from today
Micha_he
#1 Post by Micha_he » 13 Oct 2020, 20:15
I've update today to the latest source/patches and start compuile a 'normal_ESP8266_4M1M' firmware.
While the build-process the following errror is displayed:
Compiling .pio\build\normal_ESP8266_4M1M\lib3c0\Adafruit BusIO\Adafruit_I2CDevice.cpp.o
.pio\libdeps\normal_ESP8266_4M1M\Adafruit GFX Library\Adafruit_GFX.cpp: In member function 'void GFXcanvas1::drawFastRawHLine(int16_t, int16_t, int16_t, uint16_t)':
.pio\libdeps\normal_ESP8266_4M1M\Adafruit GFX Library\Adafruit_GFX.cpp:2070:30: warning: comparison between signed and unsigned integer expressions
[-Wsign-compare]
       for (int8_t i = 0; i < lastByteBits; i++) {
.pio\libdeps\normal_ESP8266_4M1M\Adafruit GFX Library\Adafruit_GFX.cpp: In member function 'void GFXcanvas16::drawFastRawHLine(int16_t, int16_t, int16_t, uint16_t)':
.pio\libdeps\normal_ESP8266_4M1M\Adafruit GFX Library\Adafruit_GFX.cpp:2620:53: warning: comparison between signed and unsigned integer expressions
[-Wsign-compare]
   for (int16_t i = buffer_index; i < buffer_index + w; i++) {
Is the problem at my vscode/platformio environment ? Can I solve the problem ?
Re: Compile error with 4M1M with latest source from today
#2 Post by TD-er » 13 Oct 2020, 20:20
That's not an error, but a warning.
Micha_he
#3 Post by Micha_he » 13 Oct 2020, 20:36
Ok, when I can ignore it..... The bin-file is created and seems to work.
#4 Post by TD-er » 13 Oct 2020, 23:06
Micha_he wrote: 13 Oct 2020, 20:36 Ok, when I can ignore it..... The bin-file is created and seems to work.
Yep this one you can ignore.
I will have a look at the warnings later.
Some other libraries also have warnings and even our own code has warnings which aren't so innocent as this one.
Users browsing this forum: Bing [Bot] and 79 guests
