ESP Easy
ESP Easy
Has anybody had any luck installing the ESP Easy image on a microcontroller? I'm trying load it into my wemos d1 mini pro and I haven't really gotten anywhere with any guides that I've found on the web. Thanks for any advice!
Re: ESP Easy
Well that's just the most used module for ESPEasy.
So I guess someone must have been lucky enough to get it working
Tell me what image you try to flash and what tool do you try to use?
Also what is the result you see when connecting to the serial port after flashing.
Make sure to also try a different USB cable and plug it into a port on the PC, not via an USB hub unless it has got its own power supply.
Users browsing this forum: No registered users and 99 guests
