General timer question
GravityRZ
#1 Post by GravityRZ » 22 Jan 2021, 08:31
i am using a timer to reset a value to zero
if XXX is not called then the timer will not start again
My question
since the timer will not start again is there any reason why i should use the timerSet,1,0 in the Rules?
eg can i delete it?
On Rules#Timer=1 do
		TaskValueSet 3,2,0
		timerSet,1,0
EndOn
On XXX do
	if [AAA#BBB] = 1
	//do some stuff
		Let,1,([CCC#DDD]/1000)+1		//set timer to current time+1
		timerSet,1,[INT#1]
EndOn
Re: General timer question
#2 Post by Ath » 22 Jan 2021, 09:04
No need to call TimerSet,1,0 in the handler for that timer, indeed, it is fired only once. TimerSet,1,0 is normally used to cancel the running timer or cancel a repeating timer, set with LoopTimerSet(_ms).
/Ton
GravityRZ
#3 Post by GravityRZ » 22 Jan 2021, 16:30
ok thanks.
i thought so since the timer did already ended
clearing up the rules :D
