hi,
is it possible to connect two (wemos D1) ESPeasy devices via cable?
USB serial or some dedicated GPIOs?
I´m especially interested in using an ESP8266 or ESP32 to conntect to a
Rasperry pi running RPIeasy to use the analoge Pins and/or Moduls that are not available for RPieasy,
without the hassle of running an hotspot on the pi.
Connect 2 units by wire
Re: Connect 2 units by wire
Hi, what exactly are you trying to achieve ? If you explain your project we can try to help you better.
Cheers !
Cheers !
i basically want what a p2p connection does, only by wire.
Although not anything as convenient as P2P, you could use the serial port for communication. Serial commands your RPI can send to ESPEasy are listed here:
https://espeasy.readthedocs.io/en/lates ... mmand.html
The ESPEasy could use rules to send string messages to the RPI. The serialsend command can be used to create special messages.
A similar concept using a Arduino and ESPEasy is documented here:
https://www.doornenbal.org/domotica/120 ... easy-howto
I don't have any other examples. Just attempting to paint a big picture to spark your imagination.
Like Thomas said, you can try using the existing communication buses between your pi & the Esp like serial, I²C or SPI. You can find a lot of examples for Arduinos & Pi on the web. But you didn't really answer my question : I understand you want a wire between the units but why ? Unless it's a big secret , we'll be able to help you better if you tell us your final goal.
because i dont want to use a wireless network.
eg i want a monitor with raspi and bme 680 to display it locally.
not everywhere wlans are allowed, and especailly slower pi´s have a hard time to have wlan and accesspoint up at the same time.
Also its a huge effort to keep up with all the extra security updates.
You're like many of my clients: I have to play Spanish inquisition with them until they finally spit it out! We're only on the second Why, the third one should work (check here https://philsvitek.com/how-to-find-the- ... hree-whys/)
TL;DR you're not telling what you want to do precisely and you focus on a possible solution you think may work. Maybe you are correct, who knows until you tell us?
If you need a remote probe for a BME680, you can use SPI or I²C from the pi to it, no need of an ESP for that.
My question is why do you need a Pi & an ESP ? If you need a screen and a probe an Esp is enough a Pi is overkill but you do you. The main advantage of the Esp is its wifi capabilities so if you don't need it, I can only assume it's because Espeasy has all the features you need like rules or format.
So, describe your project in details and where is the blocking point. I don't know if you can program or solder, I don't know what kind of hardware you possess etc.
Sorry if I sound condescending, I'm really trying to help.
Users browsing this forum: No registered users and 106 guests
