Is it possible to sent a command like from the interface from esp easy from openhab??
I use the command Pulse,15,1,100 to sent a pulse and its working. How can i do that from openhab??
i am using the MQTT Broker Mosquitto on the openhab. But i dont know how to sent from there this command.
Nikos
Sent command from Openhab
- Untitled.png (65.4 KiB) Viewed 775 times
- Untitled.png (28.12 KiB) Viewed 775 times
Re: Sent command from Openhab
You should enable a Home Assistant (OpenHAB) MQTT Controller and configure that accordingly
After setting that up you should be able to send a topic like "unitname/cmd" with payload "Pulse,15,1,100" to have that command executed (cmd is a special topic, handled like the /control?cmd=Pulse,15,1,100 you can send via http to the unit, or from the tools page)
/Ton
i have enabled the Home Assistant (OpenHAB) MQTT Controller and configured . But i dont know in openhab how to sent the payload.
where exactly to put the payload??
Thanks for your respond.
- Untitled.jpg (154.56 KiB) Viewed 768 times
We'll have to wait for someone who knows about OpenHAB to reply, as I don't have that installed, and never used it.
/Ton
Users browsing this forum: No registered users and 31 guests
