Hi.
Is it possible to fashion a rule to reboot the ESP, if it can no longer see itself on the network or in the UDP list?
Thanks,
Brian H.
WatchDog rule?
Re: WatchDog rule?
We have the ping plugin, so you could act on the events generated by a task running the ping plugin.
For example to ping the gateway.
Re: WatchDog rule?
Thanks, but can I elicit some more detail on its use?
Where is this documented?
If I put "ping" on the command line, I get as follows:
Thanks,
Brian H.
Is the "ping plugin" part of the prebuilt packages, or do I need to compile it in myself?Command unknown: ping 192.168.55.1
Thanks,
Brian H.
Re: WatchDog rule?
Plugin 89
Should be part of the "testing" build (currently ESP8266 only so it seems)
And this documentation is probably not going to help you very much, I'm afraid.... https://espeasy.readthedocs.io/en/lates ... #p089-page
Users browsing this forum: Bing [Bot] and 110 guests
