Hello.
Is there a way to set difficult debouncetimes for a Counter? Like at Tasmota - here you can set a Counterdebounce, CounterDebounceLow an CounterDebounceHigh. Is anyone knowing if there a Plugin is aviable for?
Because, i have a reedcontact that also recive false signals in ESPEASY. I have a Pullup and a capaciator - but sometimes, i get false signals. With Tasmota i can set a debouncetime for that - so that i can dissable all false signals. But the math in Tasmota is terrible
thank you.
Counterdebounce/High/Low
Re: Counterdebounce/High/Low
i would love to have this as well
i know somebody made a p222 debounced counter but i never got it to work properly.
The pulsecounter plugin (P003) does have a debounce time setting.
Isn't that enough control?
to avoid al these issues with the pulsecounter i am now trying to bypass it totally(only use the time for flow calculations)
i use a dummy device and let it trigger through GPIO
this way we have a sort of interrupt based counter instead of a 1 second base check.
to avoid false pulses i measure the time between pulses(that's where the %unixtime% comes in)
because i use the pulsecounter as watermeter and my max waterflow is around 28 liters i let it check for a delta time of 2 seconds (30 liters)
as long as the delta is equal or higher than 2 it should count, otherwise it will ignore the pulse
testing for 2 days now but i will have to wait unil i get a mismatch between the Pulsecounter and a dummy counter.
because i wait for the GPIO to change things react a lot faster.
Also the advantage of using GPIO is that i do not care if it is a falling pulse or rising pulse.
hopefully this will solve my extra pulse problem once and for all
Users browsing this forum: No registered users and 71 guests
