I plugged a rain gauge to a 'Wemos d1' running the latest ESP easy firmware version.
The objective is to mesure each bucket tipping (switch)
I configured a switch push button active low on GPIO-2 (D4) that works but ...
Even if the wemos led flash at every switch, the esp easy do not send all frames to the controller.
After investigation it seems that, if the delay of the switch interuption is lower than 100ms then the esp easy do not send all the frames (missing some).
For testing purpose I simulated 150ms and in that case every switch interruptions are correctly sent.
My question is : did I missed a configuration setting or is there a way to manage this ?
Thank you for your experience !
Ripon
ESPEasy switch minimum delay ?
Re: ESPEasy switch minimum delay ?
Probably a default setting in the controller settings.
See: https://espeasy.readthedocs.io/en/lates ... parameters
Users browsing this forum: No registered users and 58 guests
