move servo
ingoiot
move servo
#1 Post by ingoiot » 06 Mar 2021, 17:15
hi,
on touch#Touch do
  servo,1,17,1
  timerSet,1,2      //Set Timer 1 for the next event in 2 seconds
On Rules#Timer=1 do  //When Timer1 expires, do
  servo,1,17,70
  servo,1,17,9000   // servo off(doesnt work)
adding servo,1,17,9000 prevents servo,1,17,70 to happen.
can i force to run the commands in sequence or do i have to use a timer?
Re: move servo
#2 Post by Ath » 06 Mar 2021, 17:19
You have no guaranteed response-time for the servo to move from where it is to '70' so the only usable solution is indeed a timer.
I'd suggest to just time it roughly using a (stop)watch, then doubling that value for the timer value should be fine.
ingoiot
Re: move servo
#3 Post by ingoiot » 06 Mar 2021, 19:56
on touch#Touch do
  servo,1,17,1
  timerSet,1,4      //Set Timer 1 for the next event in 4seconds
  servo,1,17,70
  timerSet,2,4      //Set Timer 2 for the next event in 4seconds
On Rules#Timer=2 do  //When Timer2 expires, do
tnx
this works so far.
i hope timers do not block too much.
now if have to figure out much to much false positive touch events..
Users browsing this forum: No registered users and 93 guests
