I have not noticed all the ESPEasy-changes in the last months...
Are there any news on making a 50Hz-input workable with ESPEasy, without modify the circuit with a electrolytic capacitor? As used e.g. by MOES-switches input's.
Can we configure the switch-input-plugin (or modify the source-code), so that we get the following behavior:
1. When the signal at the input changes to 1 with a 50Hz frequency, we get a constant 1 result (only a single event).
2. If the signal falls to 0 for a period of xxx ms, then the internal result switch back to 0.
In summary: A delay only in the direction from 1 to 0.
The pulse-counter-plugin wasn't a solution in the last test (~ one year ago), because ESPEasy always crashed with the high count of pulses.
I'm searching for a solution, to use a mini-dual-switch (e.g. like this one), with dual-channel input and would like to stay with ESPEasy
Any news to use a Switch/Dimmer with 50Hz input
Re: Any news to use a Switch/Dimmer with 50Hz input
Pulse counter is capable of counting quite high frequencies these days.
So what you can do is set this to an interval of 1 sec and check the counted value.
If it does no longer increase, you can conclude the frequency was no longer present.
Does the pulse-counter only generate an event on the interval setting or on every change ?
I think (!!) it is only on the interval as it is impossible to process > 20-ish events per second and people have reported to be able to count > 200 Hz signals. (reported counting of 12'000 rpm motor)
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 112 guests
