Wifi Setup Wizard / D1 Mini ESP8266
ohaldi
#1 Post by ohaldi » 15 Apr 2021, 11:14
I could upload the firmware : ESP_Easy_mega-20200426_normal_ESP8266_4M1M.bin to my D1Mini ESP8266.
After a reset, I also could connect to the IP 192.168.4.1.
I changed the SSID and set the password. The problem after 20s nothing append. I'm still on the IP 192.168.4.1.
What are the possible causes of this problem?
Otto
Re: Wifi Setup Wizard / D1 Mini ESP8266
#2 Post by TD-er » 15 Apr 2021, 13:18
After a successful connect attempt it will save the credentials.
I'm working -as we speak- on the setup procedure which is far from perfect.
For now, as you just flashed the unit, I guess you can easily access it via serial.
So then it is the easiest to set the credentials by hand via serial:
wifissid MyWiFiSSID
wifikey MySuperSecretPassword
save
Remember you cannot correct a typo via serial, so better copy/paste it from something like notepad.
#3 Post by Ath » 15 Apr 2021, 13:52
ohaldi wrote: 15 Apr 2021, 11:14 I could upload the firmware : ESP_Easy_mega-20200426_normal_ESP8266_4M1M.bin to my D1Mini ESP8266.
It will be much easier if you pick a newer version of ESPEasy to upload, that one is almost 1 year old and many, many, improvements have been made since, especially to the Wi-Fi related stuff.
Get the latest build from https://github.com/letscontrolit/ESPEasy/releases (Expand the 'Assets' link at the end of a block of release notes text to find the actual downloads)
ohaldi
#4 Post by ohaldi » 15 Apr 2021, 17:30
Many thanks for all your information.
I alredy tested the last version from ESPEasy-mega-20210223, but also without success.
I just tested to compile my source version from 04.02.2020 with the help of Arduino. The compiled version is OK.
I also changed to a fixed IP address in the custom.h file.
The first time also did not work.
After a reboot of the device, despite the Fixed IP I had to reconnect on the IP 192.168.4.1.
I reset the device, set again in the WIfi Setup Wizard the SSID and now it's working.
it's hard to understand why now it works!
I spent more than 3 hours looking for solutions.
Otto
#5 Post by TD-er » 15 Apr 2021, 23:43
Sad to hear it is taken so long to get it to work, but on the other hand good to know the changes I have been working on the last 2 days is going to be appreciated as I promise you it will be a lot more intuitive in the next nightly build (probably this weekend or Monday)
Still have to test a few more things, but it will be fixed soon.
ohaldi
#6 Post by ohaldi » 17 Apr 2021, 09:10
I thank you for your help. I will follow the changes.
Congratulations again to the development team of this software which is very intuitive.
