email - Error connecting... - Please help
Hi All
I have been trying to use the smtp notification with out any success.
I created an smtp2go account, setup a user and have a password from smtp2go.
Domain: smtp2go.com
Server: mail.smtp2go.com
Port: 2525
Sender: xyz@gmail.com
Receiver: zyx@yahoo.com
Subject: Test Unit 1
User: smtp2go user name
Pass: smtp2go password
I have also encoded the username and password with Base64 as indicated by other forums, no luck.
Please point me in the right direction
Domain: smtp2go.com
Port: 2525
Re: email - Error connecting... - Please help
Do you get anything relevant in the log? Both positive or negative will be helpful.
Just a generic error message, irrespective of the debug level:
76954279: EMAIL: Connecting to mail.smtp2go.com2525
76954492: EMAIL: Error connecting to mail.smtp2go.com2525
I have tested the settings here - https://www.gmass.co/smtp-test and they work
smtp2go has caused issues for other ESPEasy users in the last few months. For example:I have been trying to use the smtp notification with out any success.
viewtopic.php?t=8081
Also try 80, 25, 8025 and 587Port: 2525
That testing app offers five different security setting choices. Please test all five security settings and report which work and which don't work. That info will probably be important to a dev.I have tested the settings here - https://www.gmass.co/smtp-test and they work
One more thing ...
Could be a DNS problem. Try using the IP address in the SMTP notification settings instead of the URL.
See these posts from Duelago and Shardan for details:
viewtopic.php?p=43292#p43292
Also:
https://support.smtp2go.com/hc/en-gb/ar ... IP-Address
Hi ThomasB
The "Security options that worked is:
Port 25 and 2525 work on - Auto, Tls and Tls when available - None and SSL fail.
Port 465 Work on Auto, SSL, the rest fail
Port 587 Work on Auto, None,Tls and Tls when available, the rest fail
I tried the smtp2go.com IP: 66.228.43.14 - and i get he same generic error - EMAIL: Error connecting to 66.228.43.14225, i presume that the error handler has an issue with separating the IP and the port...
I just installed RPI Easy on RPI Zero, and the settings worked on "Protocol: Plain".
I know it is not the same, but it might just help the dev. guys
Your testing revealed that your provider supports SSL/TLS on the noted ports. Unfortunately I don't believe those encryption protocols are currently supported by ESPeasy.The "Security options that worked is:
OK, your results also show that port 587 is working with "none" security (no encryption). So smtp2go's port 587 looks promising for use with ESPEasy's notification function.Port 587 Work on Auto, None,Tls and Tls when available, the rest fail
That's correct. It's an old bug. The notification's error log message code needs minor string concatenation improvements to tidy up the text output. It would be nice if there was a colon between the IP and port on the error message output.... i get he same generic error - EMAIL: Error connecting to 66.228.43.14225, i presume that he error handler has an issue with separating the IP and the port
I'm not using smtp2go.com so I can't test anything. But I recall @TD-er uses this service, so maybe he will jump in and share his setup?
Lastly, you didn't mention which ESPEasy version you are using. Be sure to try the latest Mega and perhaps something from late 2020. And report the versions you have tried.
Hi ThomasB
The version i am trying is: ESP_Easy_mega_20210223_normal_ESP8266_4M1M
I loaded the latest version - ESP_Easy_mega_20210503_normal_ESP8266_4M1M as well, changed the port to 587 and still the same error
Try one of your non-gmail account addresses in Notification's Sender field.
Beyond that I'm out of suggestions. So hopefully another user or a dev stops by to lend a hand.
I don't use smtp2go. I have reliable ESPEasy notifications using a paid ISP mail server. Nothing special in the setup other than it requires port 587.
Using these versions:
ESP_Easy_mega_20201022_test_ESP8266_4M1M
ESP_Easy_mega_20201102_test_ESP8266_4M1M
ESP_Easy_mega-20200222_normal
Users browsing this forum: Bing [Bot] and 103 guests
