Hi, I have a -03 unit that I have used for Arduino scetches. But wanted to add it to my Domoticz setup and found ESP Easy.
I have flashed it with 078 4k version and it went OK. But then it wount show any AP to connect to at boot.... Any advice?
I tried to see any output with Serial monitor but the defoult budrates dont work, what is defult for ESP easy?
ESP-03 Not showing any AP
Re: ESP-03 Not showing any AP
default ESPEasy baudrate is 115200.
When you get into the GUI you can change this in the <tools> <advanced> tab
Thank you, found the problem. I had a 1k flash unit not a 4k... Updating with 1k now it boots as AP. But I cant connect to my personal AP. It says WPA key... Dos WPA2 not work?costo wrote:default ESPEasy baudrate is 115200.
Users browsing this forum: No registered users and 109 guests
