Hi, how to connect ESP-01 and BMP085/BMP180 sensor.
A need to define something in ESP Easy firmware ?
Re: ESP-01 and BMP085/BMP180 sensor
You do not need to define anything in the software.
For the ESP-0,1 do not use a version above 20.
Once active, select in the hardware tab, via web interface a port for the SDA and one for SDC.
Connect the BMP accordingly.
You can check the connectivity in the Tools tab, with the I2C scanner.
After that, create a task in Devices and off you go.
I have followed the steps and the BMP180 get detected. I have added the BMP180 to devices but unfortunately i get no readings. I am using a ESP8266 ESP-12E board with R145_RC6.BertB wrote:You do not need to define anything in the software.
Raspberry Pi (2x) | RFXCOM RFXtrx433E USB | RFlink | Landis+Gyr ZME120ACd | USB-IR-Schreib-Lesekopf | Alecto WS1500 | Touchscreen | Yooda Sunscreen | Google Nest | Piface| kWh meter| DS18B20 | BMP180 | ESP8266 ESP-12E
Did you also enter a number in the IDX/Variable column?
Have done! but didn't work.BertB wrote:Did you also enter a number in the IDX/Variable column?
Did you enter something like 60 in Delay?
Did you use GPIO 4 and 5 for something else?
Perhaps you need a capacitor accross VCC and GND of the BMP.
Do you have pull up resistors on SDA and SCL?
Users browsing this forum: Google [Bot] and 128 guests
