AXA Remote 2.0
ManS-H
AXA Remote 2.0
#1 Post by ManS-H » 02 Jun 2016, 10:46
My situation.
I have a AXA Remote on my window, its connected with a wall control knob.
This wall control knob is modified so now i can control it with a ESP-01 (firmware R78) and a two channel relay board.
When i want to open the windows is use this:
http://192.168.0.131/control?cmd=GPIO,0,0
http://192.168.0.131/control?cmd=GPIO,0,1
I start at 8:00 with a delay of 55 sec and stop at 8.01 so i used the relay for 5 seconds. for closing the windows i have the same procedure, only with another GPIO :)
My problem that the state of the window not is visible in Domoticz. How to made that visible?
AXA Remote.JPG (30.62 KiB) Viewed 3246 times
My programming knowledge is less.
egkman
Re: AXA Remote 2.0
#2 Post by egkman » 02 Jun 2016, 16:50
Do you need actual feedback on the position of your window? you could add a proximity sensor there.
Do you need feedback on the status of your relay? check ESPeasy rules section (you will need higher ESP release) and add an extra task monitoring the relais status.
Unless you know the code, it has no meaning.
ManS-H
Re: AXA Remote 2.0
#3 Post by ManS-H » 03 Jun 2016, 10:39
The status of the relay is the problem, i used it only for 5 seconds. But with rules can be a opportunity, but i used now a ESP-01 that have only 2 GPIO ports. What ESP is then the best choice?
Users browsing this forum: Google [Bot] and 11 guests
