My situation.
I have a AXA Remote on my window, its connected with a wall control knob.
This wall control knob is modified so now i can control it with a ESP-01 (firmware R78) and a two channel relay board.
When i want to open the windows is use this:
http://192.168.0.131/control?cmd=GPIO,0,0
http://192.168.0.131/control?cmd=GPIO,0,1
I start at 8:00 with a delay of 55 sec and stop at 8.01 so i used the relay for 5 seconds. for closing the windows i have the same procedure, only with another GPIO
My problem that the state of the window not is visible in Domoticz. How to made that visible?
My programming knowledge is less.
AXA Remote 2.0
Re: AXA Remote 2.0
Do you need actual feedback on the position of your window? you could add a proximity sensor there.
Do you need feedback on the status of your relay? check ESPeasy rules section (you will need higher ESP release) and add an extra task monitoring the relais status.
Unless you know the code, it has no meaning.
Re: AXA Remote 2.0
The status of the relay is the problem, i used it only for 5 seconds. But with rules can be a opportunity, but i used now a ESP-01 that have only 2 GPIO ports. What ESP is then the best choice?Do you need feedback on the status of your relay? check ESPeasy rules section (you will need higher ESP release) and add an extra task monitoring the relais status
Users browsing this forum: No registered users and 107 guests
