Hi all
I have my esp configured to use I2C with a MCP23017. My question is how could I use a MCPGPIO as "high" sensor?
Currently I connect a switch to GND and when closed to the GPIO of the MCP. That works and I can send the data to domoticz.
But I would like to use the switch on +3,3V instead of GND. Means if I put 3,3V to the GPIO, it should trigger the switch to domoticz.
I think I have to configure the MCP23017 somehow, but I cannot find the solution.
Hope you understand the probem
Roman
MCP23017 I2C Input/Output
Re: MCP23017 I2C Input/Output
The MCP23017 has a internal pull-up to 3,3V of about 100 KOhm
If you want to have it permanently low, you need to add a pull-down resistor between GPIO and Ground.
Try with 4.7 or 10 KOhm
Thank you. Works
Users browsing this forum: No registered users and 46 guests
