Something "strang" i've used a sonoff to build inside a garden lamp. ( running ESP easy build125)
When i connect everything to test, everything is working fine and the DHT gives the temp en hum. But when i close this lamp enclosere the status in ESP Easy : NAN and the log tells me : no reading.
Is there something with this sensors like it stops working when it's build in a ( metal) enclosure ( faraday's law) ?
DHT-11 : no reading
Re: DHT-11 : no reading
Does your garden lamp have a safety earth connection and is it connected to the ground of the housesystem ?the cosmic gate wrote:Something "strang" i've used a sonoff to build inside a garden lamp. ( running ESP easy build125)
Maybe you can try to connect the ground/zero of the SonOff low voltage section to the safety ground pin which is connected to the metal enclosure.
b.t.w.
I consider the DHT11 and DHT22 as not really reliable. That is because the 2 species I have http://www.ebay.com/itm/AM2302-Digital- ... SwZVlXtGad I.C.W. ESPEasy sometimes do the same, sending NAN until I reset or reconnect power. Also one of them regularly, without any change in circumstances, starts to give RH data 10%-20% higher, for some time, while the sensors are close together. After a reboot of ESPEasy both give the same RH again. Temperature readings are always near the same.
costo wrote:Does your garden lamp have a safety earth connection and is it connected to the ground of the housesystem ?the cosmic gate wrote:Something "strang" i've used a sonoff to build inside a garden lamp. ( running ESP easy build125)
b.t.w.
Indeed this garden lamp is connected to earth (this is the lamp we're talking about http://www.meerdanlicht.nl/wandlamp-phi ... 58716.html ) I can try to connect the ground pin from the sonoff to the earth.
Otherwise i can try oneother temp sensor like the DS18b20
Maybe faraday has something to do with it.the cosmic gate wrote: Is there something with this sensors like it stops working when it's build in a ( metal) enclosure ( faraday's law) ?
It may be that the metal casing of the lamp just blocks the WiFi completely and the connection gets lost resulting in a NAN ?
Users browsing this forum: Bing [Bot] and 141 guests
