Bosch BME680 (Temperature, Humidity, Pressure and Gas) Sensor
beic
#1 Post by beic » 28 Sep 2016, 14:15
Hi there,
In case someone has interest in this new i2c sensor, Bosch BME680 (Temperature, Humidity, Pressure and Gas)!
Product description: https://www.bosch-sensortec.com/bst/pro ... cts/bme680
Documentation datasheet: https://ae-bst.resource.bosch.com/media ... BME680.pdf
As I can see from it, it will be the BMP680 variant released too ;)
So, maybe it is a good time to start working on the PLUG-IN library for ESP Easy! 8-)
Official driver (Github):https://github.com/BoschSensortec/BME680_driver
Kind regards
ledfreak3d
Re: Bosch BME680 (Temperature, Humidity, Pressure and Gas) Sensor
#2 Post by ledfreak3d » 15 Nov 2016, 11:08
looks very interesting
Domoticz Synology Esp easy Location Netherlands /Hoorn
papperone
#3 Post by papperone » 15 Nov 2016, 11:21
I read about it as well but it's way too expensive... aroudn 25$ for a single module!!
manjh
#4 Post by manjh » 15 Nov 2016, 14:35
papperone wrote:I read about it as well but it's way too expensive... aroudn 25$ for a single module!!
Probably a matter of time. Once our Chinese friends ramp up their machines and start producing this unit, I'm sure the price will drop quickly...
papperone
#5 Post by papperone » 15 Nov 2016, 15:18
yes price will drop but quality and accuracy as well :(
today BMP280/BME280 are not bad sensors but the accuracy of chinese units is close to terrible... same with DHTxx family.
Ton_vN
#6 Post by Ton_vN » 15 Nov 2016, 16:37
Any significant differences between BME280 and BME680?
;-) Same or compatible interface would be nice for implementation in ESPEasy etc.
manjh
#7 Post by manjh » 15 Nov 2016, 20:54
Accuracy is a matter of perspective.
When you want to use a sensor for medical or military purposes, it is obvious that you need to get exactly the accuracy as specified in the requirements.
But equally true: when I want to use a temperature sensor to get a grip on the average temperatures in my garage, I really don't care if it is very accurate or not, but I would like it to be linear in the fault. As long as the sensor is plus or minus half a degree accurate, I am happy... :)
papperone
#8 Post by papperone » 15 Nov 2016, 21:13
I could agree but when you have 5 sensors, same model, all reporting different readings with 5° difference or 20% diff in case of humidity i do care about accuracy!
I do not feel confortable to run multizone heating system with each zone differen readings and behavior!
Users browsing this forum: Bing [Bot] and 10 guests
