I don't get what you're trying to achieve here... It can never be ESPEasy's problem that someone doesn't know how to handle flashing an Itead POW. Many of the Itead products are using mains and modifying the product with 3rd party firmware involves competance. If you don't know what you're doing, then don't. Flashing with Espurna firmware is not more safe than flashing with any other firmware, so why not support POW with ESPEasy, when that's what people in this forum are using?costo wrote: ↑08 May 2017, 01:57 Apparently Espurna software is almost unknown here. You cannot compare Espurna with ESPEasy, they are written with totally different users in mind. ESPEasy is made for experimenters who like to add sensors or devices to the ESP unit. Espurna is written for dedicated devices, there are no plugins for new sensors. Only dedicated devices like most Sonoff devices, wemos relay shield and just a few other hardware devices are supported. No extensions are supported.
Now look at the SonoffPOW, when you open it you may get the false idea that the high voltage is separated from the low voltage part. Several slots in the board between high and low voltage give you that illusion. But what it looks like is totally false, the high voltage and low voltage share a common ground. Totally opposite from a normal Sonoff wifi switch where the high and low voltage circuits have a decent separation.
Because of this false look unexperienced people may get the unholy idea that adding extra sensors to a SonoffPOW is safe.
Imagin what will happen if these unexperienced people have ESPEasy on a SonoffPOW . . . . . . . . some people ignore all warnings and will connect sensors or a display to the RxTx-I2C bus . . . . . . . just because they can.
So I say that ESPEasy on a SonoffPOW is potentally a very dangerous situation.
Why would the developer(s) of ESPEasy create a plugin that is potentially life threatining. It could give ESPEasy a bad name. Better leave the SonoffPOW to dedicated firmware like Tasmota or Espurna.
But I do support the idea of a hardware guide like seen on Espurna's website incl. notes that you cannot connect mains and programming tool at the same time.. It should include a *disclaimer* stating that people themselves are responsible for that they are doing, that's never the responsibility of ESPEasy.
