SONOFF TOUCH - Did you see it?
ayasystems
#1 Post by ayasystems » 27 Nov 2016, 19:50
Another sonoff device!
https://www.itead.cc/sonoff-touch.html
https://www.youtube.com/watch?v=JdeZ7tMgeNw
Seems be based on ESP8285 with 1MB built in flash
ayasystems
Re: SONOFF TOUCH - Did you see it?
#2 Post by ayasystems » 15 Dec 2016, 11:51
Nice look
WhatsApp Image 2016-12-15 at 08.48.14.jpeg (109.53 KiB) Viewed 8616 times
WhatsApp Image 2016-12-15 at 08.47.43.jpeg (91.69 KiB) Viewed 8616 times
timsson
#3 Post by timsson » 15 Dec 2016, 16:12
?It works with espeasy?
NietGiftig
#4 Post by NietGiftig » 15 Dec 2016, 16:19
timsson wrote:?It works with espeasy?
What you mean?
Out of the box?
Of course not
timsson
#5 Post by timsson » 15 Dec 2016, 18:07
... Can i flash easyesp by my self? Do you have a pinout (TX,RX,GND,Vin,Gpio0) or a picture from inside?
ayasystems
#6 Post by ayasystems » 15 Dec 2016, 23:07
Yes, it is based on ESP family
timsson
#7 Post by timsson » 15 Dec 2016, 23:39
Thanks! :D
m.klinge
#8 Post by m.klinge » 10 Jan 2017, 21:49
Has anybody been able to flash esp easy onto this? :-)
/M
ayasystems
#9 Post by ayasystems » 11 Jan 2017, 07:27
Yes! I flashed
Works fine¡
m.klinge
#10 Post by m.klinge » 11 Jan 2017, 08:33
ayasystems wrote:Yes! I flashed
Works fine¡
Cool - did you do anything other than solder the pins and connect to the FTDI?
//M
ayasystems
#11 Post by ayasystems » 11 Jan 2017, 09:17
You need solder wire to gpio 0 in order to enter in flash mode and setup as esp8265 (I don't remember exactly but it is not a esp8266)
m.klinge
#12 Post by m.klinge » 11 Jan 2017, 10:54
ayasystems wrote:You need solder wire to gpio 0 in order to enter in flash mode and setup as esp8265 (I don't remember exactly but it is not a esp8266)
Ok but that's the only difference?
//M
ayasystems
#13 Post by ayasystems » 11 Jan 2017, 11:30
Nothing else. Works very fine!
m.klinge
#14 Post by m.klinge » 11 Jan 2017, 11:44
ayasystems wrote:Nothing else. Works very fine!
Good to know - I'm considering to install a few of them. Being integrated and working "like normal" has a huge WAF factor in our house :-D
//M
ayasystems
#15 Post by ayasystems » 11 Jan 2017, 11:49
Is not possible use it in place/zones with two or more walls/switchs in the line because it has only ON OFF dont do conmutation
Has two leds connected to a diferents gpio and the relay
I hope you understand my poor english
m.klinge
#16 Post by m.klinge » 11 Jan 2017, 12:47
ayasystems wrote:Is not possible use it in place/zones with two or more walls/switchs in the line because it has only ON OFF dont do conmutation
Du you mean like this:
Or like this:
//M
m.klinge
#17 Post by m.klinge » 11 Jan 2017, 12:49
Or like this:
//M
ayasystems
#18 Post by ayasystems » 11 Jan 2017, 13:41
Two switch to operate one line. In two diferent points of the room...
m.klinge
#19 Post by m.klinge » 11 Jan 2017, 14:57
ayasystems wrote:Two switch to operate one line. In two diferent points of the room...
Ahh ok - I guess that could be handled by the software by setting a rule for Switch1 to trigger Switch2?
But good to know - I only have that setup in one room in my house :)
//M
ManS-H
#20 Post by ManS-H » 11 Jan 2017, 17:12
ayasystems wrote:Another sonoff device!
To day i received my Sonoff POW, inside was this leaflet. It shows another Touch switch the you described.
See this one also not on http://www.itead.cc
Itead.cc leaflet.jpg (98.93 KiB) Viewed 7585 times
Allycat1972
#21 Post by Allycat1972 » 16 Jan 2017, 12:20
Hi Guys,
I've been looking at these since they came out, but I live in the UK and we don't have Live and Neutral in the wall switch socket. Has anyone found a way to run these in the UK?
andrew
ryanjennings
#22 Post by ryanjennings » 25 Jan 2017, 04:02
I have tried to flash R120 to a touch. All seems to go fine, but when I reboot I don't ever see the AP to connect to.
Any suggestions? I have tried both 512 and 1024. I kept gpio 0 low during boot and all appears like I have had good results with on the basic sonoff modules.
Thanks for the help,
Ryan
ayasystems
#23 Post by ayasystems » 25 Jan 2017, 07:48
Did you flash a compiled download version?
Touch is not a esp8266...you need to flash with the source code as esp8265.
ryanjennings
#24 Post by ryanjennings » 25 Jan 2017, 14:47
ayasystems wrote:Did you flash a compiled download version?
Oh thank you. I just used the same compiled download version of R120 I used for the sonoff relay. I thought the only difference was the onboard memory. I will give compiling a try.
It worked.
Thanks again for the quick reply,
Ryan
toffel969
#25 Post by toffel969 » 08 Feb 2017, 07:38
chip is actually a esp8285, it is like a esp8266with 1mb flash integrated (on chip). usually has an ipex connector. has slightly better deep sleep consumption
xbmcnut
#26 Post by xbmcnut » 11 Feb 2017, 05:27
Did a quick video with full how to guide in the description. Enjoy. Works a treat!
https://www.youtube.com/watch?v=s5gbdy0niAs
Numerous Sonoff's and Shelly's, Home Assistant on Intel NUC i3, Aeotec Z-Stick (Gen 5), deCONZ Zigbee Stick, 3 x Echo Dot's and 5 x Google Home
drbrains
#27 Post by drbrains » 17 Feb 2017, 16:49
I found a 2 gang sonoff touch "look-a-like". It works the same with the ewelink app and it is based on the PSB-B04-GL. On the itead support site I can find the pin-out for this module. However I am not able to find the rx/tx pins to flash espeasy (or anything else) on it.
I found this module is used in other applications as well like the usb 5v, 4 ch. relay.
Anyone know how to connect tx/rx and pull GPIO 0 LOW?
psy0rz
#28 Post by psy0rz » 17 Feb 2017, 17:07
If someone has the correct esp8285 platformio.ini environment settings for me, I could add it to our travs-script.
That way there will be also an automated firmware.bin release for the esp8285 from now on. (saves a lot of people a lot of compile-hassel)
Edwin
Please support ESPEasy development via Patreon or buy us a coffee.
xbmcnut
#29 Post by xbmcnut » 20 Feb 2017, 00:02
drbrains wrote:I found a 2 gang sonoff touch "look-a-like"
Can you provide a link to the hardware?
drbrains
#30 Post by drbrains » 20 Feb 2017, 04:51
The box is labelled Tantech: http://tantech.taobao.com
However, I got it from the Itead webstore on Taobao. Those are non-branded. I got them flashed and working (see my other post)
xbmcnut
#31 Post by xbmcnut » 20 Feb 2017, 08:31
drbrains wrote:I got them flashed and working (see my other post)
Thanks for that. You flashed them with Espurna though? I just tried over the weekend but had to jump through hoops under Windows with Platformio to get a Wemos flashed (five different Windows programs required). Certainly a long way from being as easy as ESPEasy, my go to firmware.
drbrains
#32 Post by drbrains » 20 Feb 2017, 09:21
Yes, I did flash with ESPurna cause ESPEasy does not support the extra SIL F330 chip between the switch and relay and the serial port on the ESP8266ex. Maybe someone could write a plugin like the ser2net one to talk with the F330. However since it is a wall switch in the end, all I needed was a way to talk to it without the e-we link cloud and use my own MQTT broker with Domoticz.
I am slowly replacing my older 433mhz switches which don't provide feedback when switched manually On/Off with a Wifi (esp) version. I am using ESP Easy on the SonOff S20.
xbmcnut
#33 Post by xbmcnut » 20 Feb 2017, 09:26
drbrains wrote:I am using ESP Easy on the SonOff S20.
Thanks! Good to know. I would get some of those if they sold the multi socket version like the one on https://world.taobao.com/item/527467680727.htm#detail
Wavemaker
#34 Post by Wavemaker » 23 Feb 2017, 16:00
These sonoff touches suddenly make it very interesting to automate switches due to the low cost!
Personally however, I don't like very much the look of the face plate. Can somebody comment wether it is easy to replace the face plate, e.g. with one of Livolo?
Such as this one:
https://www.aliexpress.com/item/Livolo- ... 21458.html
Users browsing this forum: Bing [Bot] and 13 guests
