Support for PZEM 004T Energy monitor
Re: Support for PZEM 004T Energy monitor
What do you mean?
This sensor is using the (Hardware) serial port, so you must uncheck "Enable Serial port:" on the Tools->Advanced page.
This does make sure no logs are sent to the serial port and also any incomming data is not interpreted as commands and thus allows exclusive access to the serial port for the plugin.
I have kept the settings as it is and still receiving accurate readings.TD-er wrote: ↑22 Oct 2020, 16:28 What do you mean?
finally, how is it possible to compile easily PZEM plugin ?
i tried with P171 from playground, but it complains no *.h library as it is not provided.
and from this source , https://github.com/djelau/ESPEasyPlugin ... v30-master i don't see the trick as it is not a plugin format
Thomas
Thomas
Isn't the code in the mega branch working as it should?
See P102: https://github.com/letscontrolit/ESPEas ... 004Tv3.ino
thanks, I miss it as it was not declare in Custom_Sample.hTD-er wrote: ↑17 Dec 2020, 22:22 Isn't the code in the mega branch working as it should?
Yep that one needs an update as well indeed.
I have seen, that now following firmware exists:
ESP_Easy_mega_20210114_energy_ESP8266_4M1M.bin
Is the functionality the same as the version compiled from DJELAU?
I have not tested it myself.
The only thing I did, was update the existing code from the playground to match the current code base and thus it should be functional identical, or at least do what the original code did + probably some more as added in newer code changed in the ESPEasy core.
Thank you for your reply
I will test it and let you know if the functionality is the same
- Andrew Mamohin
I installed this firmware a few days ago. Yes, the plugin works fine. But, I had to configure the PZEM device again.
Andy.
The plugin got a new plugin-id when it was moved from the plugin-playground to the main repository (to keep the numbers consecutive). As the settings are related to this plugin-id you'll have to re-configure.Andrew Mamohin wrote: ↑17 Jan 2021, 06:44 I installed this firmware a few days ago. Yes, the plugin works fine. But, I had to configure the PZEM device again.
/Ton
- Andrew Mamohin
