I got the Sonoff LED, an ESP8266-controlled driver and 4 led strips mounted on aluminum. Nice quality, cold and warm light, very bright (driver voltage is extremely high with 96-140V)...
Flashing ESPEasy is absolutely no problem, on the daughterboard that holds the ESP8266 there is even a button wired to GPIO0, so no soldering necessary...
Here is the IO-configuration:
Button GPIO 0
LED (internal) GPIO 13, active low
Cold LED GPIO 12
Warm LED GPIO 14
The internal LED is barely visible within the enclosure, so no practical worth.
I'm using PWM for both cold and warm LEDs, and I see no flickering so far.
Cheers, Joe
Sonoff LED
Re: Sonoff LED
I just got one myself. Since the board already is prepared with RBG and the EPS8266 GPIO pins are attached do you think it is possible to use RGBW stripes with this controller with modified firmware?
Users browsing this forum: No registered users and 41 guests
