Reflashing firmware.
homerruma
#1 Post by homerruma » 21 Feb 2017, 19:57
Hello everyone
I am flasing my ESP01 and I saw him in the network as ESP_0.
After some time not see ESP_0
To check ESP01 I reflashing ESP01 the defaul AT Firmware and see device in network as ESP_F25B2A.
I concluded that the correct ESP01.
The following is a flash firmware ESPEasy R120.
But I do not see ESP01 in network with name ESP_0.Anyone know what's the problem?
Sory for bad english
paxi
Re: Reflashing firmware.
#2 Post by paxi » 21 Feb 2017, 22:21
Erm, I think you posted screenshots but there is nothing to see. Please edit your post. ;)
vorsselmansP
#3 Post by vorsselmansP » 24 Feb 2017, 10:41
I could be wrong because i'm also new with the esp here
ESP_0 will only come up if the ESP can not connect to your home network.
So when it disappears it is connected onto your home network and probably by DHCP so it is hard to figure out which IP it has got.
Unfortunatly it hasn't got a HOST Name when connected to your home network so it will not reponde to http:\\newdevice
If your ESP is still connected through serial line then open a terminal and type Settings and enter
Otherwise use AngryIPScanner to see which IP adresses are on your network
running Domoticz on a raspberry pi.
mi-light on domoticz
basic knowledge in electronics
Currently developing in python
Users browsing this forum: Google [Bot] and 13 guests
