ESP-01 strange response
Posted: 17 Mar 2017, 12:06
by velja
I have one ESP-01 1M with response after reset like in the attachment. I try different baud rate but no success. I can flash it, try R120, R147, R148, V2.0.0.0 - result is the same. I also try LUA flasher, various combination (erasing, full flash....) and nothing. Whats wrong?
Re: ESP-01 strange response
Posted: 18 Mar 2017, 17:11
by paxi
Do other ESP's work?
Which USB/UART adapter is used?
Posted: 18 Mar 2017, 21:02
by velja
pl2303 on 3.3V. It works fine on every other module.
- USB-To-RS232-TTL-PL2303HX-Auto-Converter-Module-for-Arduino-Converter-Adapter.jpg_640x640.jpg (39.88 KiB) Viewed 6272 times
Posted: 20 Mar 2017, 00:49
by paxi
Smells like FTDI chip. Let me guess - you're using Windows 10?
Try again with a different unit, most likely it won't work also: Welcome to
FTDIgate mk2.
If it uses a fake chip (99% of them do) then the latest driver update made it talk bullshit.
Solution: avoid anything with FDTI on it and use an adapter with cp2102 or ch340 chips.
Edit: it's not an FTDI but it seems Prolific plays the same game with fake chips...
Posted: 23 Mar 2017, 21:52
by velja
OS is windows 7. Chip is PL2303HX. I use few ESP moduls (ESP-01 and ESP-12) with no problem.
Posted: 24 Mar 2017, 01:55
by Shardan
Seems that newer ESP-01 (the V3) have some strange behaviour.
Maybe check this thread:
https://www.letscontrolit.com/forum/vie ... f=5&t=2780
