LCD with two alternating sets of display lines?
I am using an LCD screen with four display lines, and have run out of room.
It would be nice to have two separate sets of lines, which display alternating.
So first display the 1st set of lines, then after (say) 30 seconds display the second, etcetera.
I don't think this is a function at this moment, but would it be very difficult to do this?
Re: LCD with two alternating sets of display lines?
I think this function is implemented in" framed LCD plugin"manjh wrote: ↑29 Aug 2017, 23:57 I am using an LCD screen with four display lines, and have run out of room.
Edit: it is the oled plugin not lcd.
Yo should be able to achieve the functionality with rules.
Yes it's possible. The commands shown under http control are also available in rules:
https://www.letscontrolit.com/wiki/index.php/LCDDisplay
Just use the lcd command in rules in combination with 2 timers.
Ah, good idea! At system boot start timer1 with 30 secs, timer2 with 60. Then for each timer display the appropriate lines and restart the timer for 60 secs.toffel969 wrote: ↑30 Aug 2017, 08:02I think this function is implemented in" framed LCD plugin"manjh wrote: ↑29 Aug 2017, 23:57 I am using an LCD screen with four display lines, and have run out of room.
I think this will work, will play around with it a bit.
edit: tried it, and this works just great!
Understand. But that would put the control in Domoticz (in my case), and I would prefer an ESP that is not depending on that.toffel969 wrote: ↑30 Aug 2017, 08:21 Yes it's possible. The commands shown under http control are also available in rules:
I'll go for the "rules" solution and see where that brings me.
One last question, is there a list of commands?
In the ESPEasy command reference I find a link to the LCD Display page, and there I can see four:
simple write, clear, on and off.
Is there more? Such as line-clear, blink on/off, cursor position?
Not that I'm aware of. What do you mean by dependant o domoticz, it's all in in rules
As far as i can see from the code there are no further commands.
Pity. Clearlline would have been useful, especially when I use text of varying length. If a displayed lline is shorter than the previous, it will leave some of the old text visible. The only options now are to either clear the whole screen, or display exactly the max number of characters of a line.
Users browsing this forum: Bing [Bot] and 128 guests
