I've been banging my head against a wall trying to get 2 US sensors working right. I have second esp running with 2 and it's been fine but i made another with 2 more US sensors in a different position and I cannot get solid readings from them.
But I think I finally figured it out. Most of the time these 2 sensors will not pick anything up. In other words, they'll be trying to measure a distance that is beyond 400CM.
When they're in this state I get some crazy numbers out of them like:
547285 : SR04 : Distance: 9435517.00
or it says something else..unknown distance or something. I can't remember right now.
Is there a way to report the distance as out of bounds (like 1000 or 0 or something) when there is nothing within range?
HC-SR04 default value for over max distance
Re: HC-SR04 default value for over max distance
With rules and dummy device you can do this.
Yes I am using that exactly, works perfectly
You check the value for "sanity", then you write it into a dummy device. Further reactions only when the dummy is rewritten.
On dist#scr4<400 do
Taskvalueset,7,1,[dist#scr4]
Taskrun,7
On distance#dummy do
whatever
Users browsing this forum: No registered users and 120 guests
