I am a neophit with the
I tried to install ESP easy on a WEMOS D1 (not R2).
ESP easy work fine, but I sensors are not detected.
I don't know why. I tried with a BMP180 and DHT22.
For example : DHT22 connected to PIN (+5V, Grnd, D8) + R 4.7KOhm pull up.
Does Esp Easy support Wemos D1 ?
What's wrong in my work ?
Thank you very much
Fabien
Wemos D1 not supported ?
Re: Wemos D1 not supported ?
Have you read the wiki?
It mentions Wemos D! as being supported but also stated GPIO15 (D8) should not be used for connecting DHT22.
Thank you for your answer.
I read the wiki, but I don't remember that pin D8 should not be used for DHT22.
Now it works fine !
Other pb : I tried with a BMP180 and PIN SDA/SCL, but no sensor is detected.
I2C scan detect nothing.
Do you have an idea ?
Thank you for advance.
Best regards
Now it works fine !
Best regards
It works !
the pins soldering was bad.
sorry for inconvenience
Users browsing this forum: Google [Bot] and 126 guests
