Hardware Support Request
Would it be possible to support the HC-SR501 PIR motion sensor and the INA219 DC Current sensor boards please?
Jay
Jay
Re: Hardware Support Request
The HC-SR501 PIR motion sensor is already supported because it actually works like a switch.
The I2C INA219 board would be usefull to measure DC-currents. I support the request.
Thanks for letting me know about the HC-SR501. Might be handy to add it to the wiki?costo wrote:The HC-SR501 PIR motion sensor is already supported because it actually works like a switch.
I'm planning on using the INA219 board to know when my milights are actually on as they don't provide feedback.
Jay
found out that the HC-SR501 is not that stable if used on 3.3V (I think it's restarting each 10sec).
Working well if VCC is getting 5V.
The HC-SR501 needs 5Volt, as there is a regulator on board
But you could connect 3.3V after this regulator, then it works
Another problem i realized:
If you put both the HC-SR501 and the ESP in an enclosure where they sit behind each other, you get distortions,, it won´t work
I've ordered one of those INA219 boards from China. Will see what we can do when it arrives...jay_s_uk wrote:Hello,
Jay
Thank you. Mine comes next week.Martinus wrote:I've ordered one of those INA219 boards from China. Will see what we can do when it arrives...jay_s_uk wrote:Hello,
Jay
Looking forward to playing with it
@Martinus Got my INA219 in the post if theres anything you want me to do with it whilst waiting for yours?
You could download R66 from github, it has the first INA219 plugin release:
But it seems to work.
I only have a small LED attached to 5 volts USB power, so the current reading is not very impressive...But it seems to work.
Have tried it with my LED strips and it all works fine.
Thanks again
Edit****
I had to change the address in the plugin as it was conflicting with another device.
The INA219 has 4 different available addresses, 40, 41, 44 and 45.
Would it be possible to add this to the devices page? That way I can use the OTA function without having to edit the file before hand.
Thanks again
Edit****
Users browsing this forum: Google [Bot] and 117 guests
