Can't find TSO4838 device
- dynamicdave
I'm trying to find the "Device" dropdown to interface with the IR receiver TSOP4838.
I'm currently using mega-20180924 Normal and Test version.
Does anyone know which version of ESP Easy the IR receiver can be found???
Kind regards from David
Re: Can't find TSO4838 device
Try the IR version.
There's a separate version for IR now as the IR-Library gets too big.
- dynamicdave
Thanks for your swift response.
Now why couldn't I see that version/entry in the release I downloaded today??
Might be time for an eyesight test !!!!
Thanks again.
Thanks again.
- dynamicdave
Hi Shardan,
Do you know if the TSO4838 should respond to a TV remote??
When I used to use the old TSO1838 devices (many years ago with PIC microcontrollers) I had to fire an IR beam that was modulated with a 38KHz carrier.
Does the TSO4838 work in the same way??
Kind regards from David.
Hi David,
atm i have to pass out on this.
The TSOP4838 uses 38KHz... TSOP48 is the type and "38" the frequency.
With the old R148 ESPEasy I used an arduino with a TSOP 4838
to read the IR remote and (hopefulls..) get back a usable code.
A description of the settings and commands is in the wiki: https://www.letscontrolit.com/wiki/inde ... /IR-Remote
Due to lack of time I didn't do anything with the new IR-binary yet so
I can't say how it works and which values are returned.
- dynamicdave
I've just been trying to get a TSOP4838 IR receiver working with ESP Easy.
I'm using the IR version of mega-20190109.
Has anyone managed to get the IR receiver working and if so, with which firmware version?
Kind regards, David
Kind regards, David
- dynamicdave
Responding to my own post - that's strange.
Well I have made some progress - I made a small test circuit (without using a Wemos, just an LED and a resistor) and discovered the TSOP-4838 doesn't seem to work off +3.3V supply only 5V.
The datasheet says it should work on +2.7v to 5.5V.
I then made up a breadboard with a Wemos and powered the TSOP-4838 from the +5V connection.
I made up a down level shifter using a couple of resistors and finally got number-strings coming out of the device.
If I allow a short delay or break between pressing a button on the remote IR controller, the number strings seem fairly repeatable.
If I press the button quickly then I get a different number-string each time.
Well at least I've made progress.
Hi Dave,
take a look at
https://letscontrolit.com/wiki/index.ph ... /IR-Remote
That's the IR transceiver i've designed some time ago... still working on an old R148 Version
as I didn't find the time to change to new version including adaption of my FHEM config.
take a look at
