Cannot get LCD to work
Drowwy
#1 Post by Drowwy » 26 Dec 2018, 14:54
Hi, I'm on build 20181220 on a Nodemcu V3. I try to connect an LCD 2004.
On the I2C scan it finds the lcd on address 0x27.
Now, when I enable the device and write "IP %ip%" on the first line, the display remains blank.
Also, I'm not really sure what interval is for.
Thanks for any hints.
RobertM
Re: Cannot get LCD to work
#2 Post by RobertM » 26 Dec 2018, 17:33
Do you connect "VO" pin (contrast) :?:
Domosapiens
#3 Post by Domosapiens » 26 Dec 2018, 18:17
potmeter adjustment ?
RobertM
#4 Post by RobertM » 26 Dec 2018, 18:25
yes
Drowwy
#5 Post by Drowwy » 01 Jan 2019, 16:58
Hey thanks for the reply. I connected the four pins GND,VCC,SDA and SCL.
EDIT: The tip with the potmeter helped but the highest contrast is still barely visible.
Drowwy
#6 Post by Drowwy » 01 Jan 2019, 17:16
The text is weak in dark color instead of being bright and white on the blue background.
Domosapiens
#7 Post by Domosapiens » 01 Jan 2019, 17:42
Display needs 5V.
Use a level-shifter for SDA and SCL.
Drowwy
#8 Post by Drowwy » 01 Jan 2019, 18:21
Okay, I will try that, thanks.
Domosapiens
#9 Post by Domosapiens » 01 Jan 2019, 18:50
Drowwy
#10 Post by Drowwy » 01 Jan 2019, 19:20
As I am a beginner that line didn't ring a bell for me when I read it.
Luckily I have bought plenty of different parts in advance and I found a level shifter.
Now it works like a charm.
Maybe the wiki entry could be dumbed down for beginners like me, that think it's enough to plug&play.
Anyways, thanks a lot for the advice. I'm looking forward to play with that lcd :D
(for beginners like me: lv is 3.3v, gnd is gnd, lv1 is sda old, lv2 is scl old
then on the other side: hv is 5v source, gnd is correlated gnd, hv1 is sda new, hv2 is scl new)
velja
#11 Post by velja » 12 Dec 2019, 09:57
I like to sugest to author of plug-in for I2C LCD 2004 to extend range of I2C address to 0x4f (http://www.ti.com/lit/ds/symlink/pcf8574.pdf page 13 ).
Thank you
#12 Post by TD-er » 12 Dec 2019, 11:27
velja wrote: 12 Dec 2019, 09:57 I like to sugest to author of plug-in for I2C LCD 2004 to extend range of I2C address to 0x4f (http://www.ti.com/lit/ds/symlink/pcf8574.pdf page 13 ).
Thank you
I added an issue for it, so it will not be forgotten.
See https://github.com/letscontrolit/ESPEasy/issues/2813
velja
#13 Post by velja » 12 Dec 2019, 11:44
Nice,
efyzz
#14 Post by efyzz » 23 Nov 2020, 23:29
I have connected an ODROID 20x4 LCD from Pollin:
https://www.pollin.de/p/odroid-h2-i2c-2 ... dul-810957
I can see the text on the display, but it is also weak and dark and not white as it should be. If I reconnect the display while ESPeasy is running, I get (of course) random characters, but they are bright white!
So it doesn't seem to be a matter of voltage. The display is specified for 3.3V by Pollin and in the ODROID guide it is also connected to 3.3V.
https://wiki.odroid.com/odroid-h2/appli ... d#tab__h21
So it seems to be a matter of initialization...?
Thanks for your help!
efyzz
#15 Post by efyzz » 25 Nov 2020, 22:53
I found that the display should have a charge pump to get the needed LCD voltage if VCC is 3.3V.
But this charge pump is not fitted on my display, so it is not for 3.3V use :( Thanks, Pollin ...
But fitting this charge pump may be an alternative to 5V and I2C level shifters.
https://www.element14.com/community/gro ... cds-to-33v
Users browsing this forum: Google [Bot] and 14 guests
