Is it possible to use this fingerprint sensor with ESPeasy? Someone with experience here?
https://randomnerdtutorials.com/fingerp ... h-arduino/
I would like to read the fingerprint and get the result via MQTT (match/no match)
Help would be highly appreciated ... Thank you in advance.
Fingerprint sensor FPM10A with ESPeasy?
Re: Fingerprint sensor FPM10A with ESPeasy?
Put Arduino between fingerprintsensor and ESPeasy.
Arduino through available library decides whether the fingerprint is valid, and send event "valid" to ESPeasy.
Or you can define events:
carol_valid
peter_valid
linda_valid
If you need distinguish users.
You can simply send these command via serial line to ESpeasy from Arduino.
carol_valid
peter_valid
linda_valid
Users browsing this forum: No registered users and 130 guests
