BMP280 pressure publishing problems [solved]
Posted: 10 Apr 2019, 12:19
In my setup (Wemos D1 / Espeasy 20190404 / BMP280), the pressure value is not published over MQTT.
In the DEVICES window, it clearly show values for Temp (14.1) Humidity (0) Pressure (1018.4), Humidity is 0 because it is a BMP280.
Looking at the log window, it shows correct values for Temp and Pressure (Humidity is not shown here).
When subscribing with MQTT tool, it only publish a correct value for Temp, Humidty = 0 but NO Pressure topic and value.
It looks like ESPEASY is publishing Humidity instead of Pressure ...
Any thoughts ?
-ben
Any thoughts ?
-ben
