No I2C with Sonoff 4CH R2
ajheyworth
#1 Post by ajheyworth » 20 Apr 2019, 09:06
Just diving into a Sonoff 4CH R2 which provides 4x relay outputs, a couple of unused GPIO pins on the board and 4x inputs tied to buttons.
I want to add an MCP23017 port expander to gain some more useful IO on the side and also for an OLED screen.
Q1. Trawling the internet it would seem that GPIO 01 and GPIO 03 are used for I2C. Does anyone else concur?
Q2. In ESP Easy Mega software, it seems that GPIO 01 and GPIO 03 are greyed out, so can't be allocated for I2C, yet I cannot see them allocated anywhere else.
Whilst on this topic...
Q3. Has anyone come across a very cheap IO breakout board tied to a port expander/circuit - just to provide a combination of both input and output connections? I've seen the relay boards, but am specifically looking for more inputs to reed switches etc.
Many thanks
papperone
Re: No I2C with Sonoff 4CH R2
#2 Post by papperone » 21 Apr 2019, 08:19
ajheyworth wrote:
20 Apr 2019, 09:06
As far as I know the standard I2C pins are GPIO4 and GPIO5 and I use them in quite few projects....
ajheyworth
#3 Post by ajheyworth » 21 Apr 2019, 08:27
papperone wrote:
21 Apr 2019, 08:19
ajheyworth wrote:
20 Apr 2019, 09:06
Here is the known GPIO list for the Sonoff 4CH R2:
GPIO 00 - Button 1
GPIO 04 - Relay 3
GPIO 05 - Relay 2
GPIO 09 - Button 2
GPIO 10 - Button 3
GPIO 12 - Relay 1
GPIO 13 - WiFi LED
GPIO 14 - Button 4
GPIO 15 - Relay 4
papperone
#4 Post by papperone » 03 May 2019, 07:10
ajheyworth wrote:
21 Apr 2019, 08:27
GPIO 00 - Button 1
GPIO 04 - Relay 3
GPIO 05 - Relay 2
GPIO 09 - Button 2
GPIO 10 - Button 3
GPIO 12 - Relay 1
GPIO 13 - WiFi LED
GPIO 14 - Button 4
GPIO 15 - Relay 4
Then there are chances you can't use I2C with yout sonoff 4CH Pro due to the fact you have no good GPIO avail for the protocol.
I can confirm GPIO1/3 are the hardware serial and probably can't be used reliably for I2C communication.
toffel969
#5 Post by toffel969 » 03 May 2019, 11:48
papperone wrote:
03 May 2019, 07:10
ajheyworth wrote:
21 Apr 2019, 08:27
GPIO 00 - Button 1
GPIO 04 - Relay 3
GPIO 05 - Relay 2
GPIO 09 - Button 2
GPIO 10 - Button 3
GPIO 12 - Relay 1
GPIO 13 - WiFi LED
GPIO 14 - Button 4
GPIO 15 - Relay 4
You can use GPIO1/3 as I2C after disabling serial in advanced tab.
Users browsing this forum: No registered users and 6 guests
