Hello!
Is this sensor Capacitive Touch Sensor Controller Module I2C keyboard
works with espeasy mega-20190511?
I found some information here and here but can't make it work.
Conneected :
SCL- GPIO12 (D6)
SDO- GPIO13 (D7)
Device- Keypad - TTP229 Touch
MPR121 touch sensor
MPR121 touch sensor
- ttp221.png (14.41 KiB) Viewed 3913 times
Re: MPR121 touch sensor
It's not the same IC as the plugin?
IC on my board MPR121
IC in espeasy mega-20190511 -TTP229
but Plugin 062: MPR121 KeyPad says it should work properly but i don't see it in devices in espeasy.
Which version are you running? Test?
Finally i found some old firmware on my laptop. mega-20180421 in test version there is MPR121 sensor and it work properly.
Only one issue- if we set up this sensor but do not connect it esp will not boot up.
Please file an issue on GitHub.
Users browsing this forum: No registered users and 76 guests
