Support for Wifi Irrigation Timer
Hi all,
is there someone who have done something for this product ? :
https://www.youtube.com/watch?v=T1VzW28_dRY
http://remotecontrolautomatic.com/wifi_ ... trol_2.php
I know this product use :
OS details: Espressif esp8266 firmware (lwIP stack), NodeMCU firmware (lwIP stack)
Thanks for your return.
Interrupteur
Interrupteur
Re: Support for Wifi Irrigation Timer
Link from shop does not link to item
What does it cost ?
A valve + NodeMCO or Wemos Mini + relay + power supply + Housing = your total
Or valve + Sonos + housing = your total
In the end a DIY functions better ... because you built it and possibly be more reliable and rebuildable.
For irrigation after a lot of thought I use rainwater and IBC’s for storage and everything by gravitation with this type of valve : [https://www.aliexpress.com/item/322376 ... 4c4d3GQq4g and tubing of course a lot
If you are here, you can as well built it
What does it cost ?
Belgium and land of ESP ... counting
Hi HomeJCL,
thanks for your return...
The problem is i bought this product yet before i know the forum (lets control it).... So now i have it, i don't want to use it with Cloud Chinese ! I want to manage it in local area (Lan)...
Interrupteur
Interrupteur
Is this the same product:interrupteur wrote: ↑16 Aug 2019, 09:43 Hi HomeJCL,
Interrupteur
https://www.banggood.com/WIFI-Automatic ... ehouse=USA
https://nl.aliexpress.com/item/32813449 ... 5a2axAtAOa
Hi ManS-H,
Thanks for taking time to respond to me, it's very nice.
That's right, this the same product !!!
I hope it exists a solution....
Interrupteur
Interrupteur
interrupteur wrote: ↑16 Aug 2019, 15:54 Hi ManS-H,
Interrupteur
Simple question, can You open the module?
Good question... I don't know. I must to stop it before because actually it's in the garden and is in use...
I'll let you know...
I didn't find anything about this unit. Go for a diy solution with a Wemos and a valve. Then you have full control.interrupteur wrote: ↑16 Aug 2019, 16:32 Good question... I don't know. I must to stop it before because actually it's in the garden and is in use...
Look here:
viewtopic.php?t=5610
Users browsing this forum: Bing [Bot] and 56 guests
