No wakeup after complete discharge of the batteries
spicer
#1 Post by spicer » 03 Sep 2019, 18:58
German:
Hallo Gemeinde
Warum bootet der ESP8266 nicht, nachdem die Akkus komplett entladen waren und die Solarpanels wieder Strom liefern?
Ich denke, das dies wegen dem langsamen Spannungsanstieg ist.
Gibt es einen Trick (wie ein R-C Glied), um das hinzukriegen?
Translator:
Hello community
Why does the ESP8266 not boot after the batteries have been completely discharged and the solar panels are supplying power again?
I think that's because of the slow increase in voltage.
Is there a trick (like an R-C link) to do that?
Re: No wakeup after complete discharge of the batteries
#2 Post by grovkillen » 03 Sep 2019, 19:10
Perhaps using a voltage regulator in-between?
spicer
#3 Post by spicer » 03 Sep 2019, 19:14
Yes. I use a step down converter (7-12V to 3.3V).
#4 Post by grovkillen » 03 Sep 2019, 19:34
Aren't you powering it with 5V?
#5 Post by ThomasB » 03 Sep 2019, 19:35
One way to solve this is to use a brown out detector. This provides a reset after the voltage becomes valid. Same concept as the Power Good ("PWR_OK") signal on a ATX PC power supply.
For example: http://www.hnilica.cz/radek/zim/Electro ... cuits.html
spicer
#6 Post by spicer » 03 Sep 2019, 19:36
No. 3.3V.
5V is very bad for the ESP :D
#7 Post by grovkillen » 03 Sep 2019, 19:37
So what board are you using since you don't have a 5V VIN?
spicer
#8 Post by spicer » 03 Sep 2019, 19:44
ATM i use a nodeMCU and give power over 3V pin. Vin is not connected. I know, is not a clean solution :)
Later i will use a "naked" ESP-12F modul.
spicer
#9 Post by spicer » 03 Sep 2019, 19:47
ThomasB wrote:
03 Sep 2019, 19:35
Yes. This is a possible solution. With the TCM809 easy :)
#10 Post by TD-er » 03 Sep 2019, 21:15
Maybe the ESP is trying to boot and thus discharging the battery more than the panels can charge it.
The EN pin on the ESP must be pulled high to boot the ESP.
Maybe you can make a simple trigger to only pull it high above some level to give the panels opportunity to get the batteries charged again.
It could also help to prevent discharge below some level.
spicer
#11 Post by spicer » 03 Sep 2019, 21:30
Good idea.
I still have unused OpAmps.
This allows me to build a Schmitt trigger for the EN.
#12 Post by ThomasB » 03 Sep 2019, 23:00
I still have unused OpAmps.This allows me to build a Schmitt trigger for the EN.
Don't forget that this application will require a micropower OpAmp; Single supply, rail-to-rail, and capable of operating at very low voltage.
spicer
#13 Post by spicer » 03 Sep 2019, 23:06
Is a LMC6482.
But i think, i solve this with ThomasB's "brown out detector".
spicer
#14 Post by spicer » 05 Sep 2019, 19:44
I build a circuit.
If the voltage (Ubat) is to low (adjustable with R4) the EN is L.
V1 (3.3V) is after the step down converter.
It works ^^ Thx TD-er
#15 Post by TD-er » 05 Sep 2019, 19:52
Maybe you also want to add some hysteresis, or else it would not be able to charge the batteries again and keeps rebooting if the current needed for booting is pulling the voltage just below your set threshold.
spicer
#16 Post by spicer » 05 Sep 2019, 20:01
That's what I thought about first.
But if the power is insufficient when booting, the EN is immediately set to L again.
A "flickering" would of course be possible and not desirable.
When I apply a resistor from out to +, I have a hysteresis (non-inverting Schmitt-trigger).
#17 Post by TD-er » 05 Sep 2019, 23:34
Maybe also place some small capacitor parallel to R4 and one over V1.
I can imagine the DC/DC converter and the charging circuit may not give the most clean signal.
So by adding a small capacitor over them, you will eliminate most of the spikes introduced by those converters.
In order to simulate, you may need to add a 50 kHz (or more?) signal on top of your sine wave with an amplitude of 50 mV (?)
Wiki
#18 Post by Wiki » 06 Sep 2019, 13:50
It would be helpful to get an idea about your power supply scheme. Do you use a protection board for liion batteries?
If yes, have a look at its datasheet. Most protection boards are starting the charging cycle after shutdown of the power supply caused by low voltage of the battery with very low current. So switching the ESP on too early means that you won't get the battery alive again. You will have to charge the battery at least up to 3.2-3.3V before switching the ESP on to get the circuit alive.
This is the reason why power banks in most cases don't deliver power while being charged.
spicer
#19 Post by spicer » 06 Sep 2019, 15:40
I use two (serial) Panasonic 18650 NCR18650B Li-ion battery 3.7V with protection PCB 3400mAh.
Simple way :D
Drum
#20 Post by Drum » 20 Oct 2019, 05:14
Something like this might be easier. Reading the thread reminded me it is on my to do list. I currently use a simple one which shuts down the voltage regulator when the battery voltage gets too low. Originally I set it to shut down the voltage regulator when the vr output was too low... :o
https://www.onsemi.com/products/power-m ... ors/ncp304
From testing
At 2.2v esp restarts
At 2.1v shutdown
From 2.1 to about1.5v esp will restart with voltage increase
1.5v or below esp requires complete power off to reset
