capacitive soil moisture sensor with wrong data
Problem with capacitive soil moisture sensor (https://www.ebay.de/itm/Kapazitiver-Ana ... ensor-TFZ/): I calibrated this perfectly (once completely dry and once under water ). However, he always returns completely wrong numbers, sometimes in the minus range. The supply cable is about 2 meters long. The moisture meter is connected via ADS1115. Another, identical device is working properly. Is there a trick, maybe with a resistance?
Re: capacitive soil moisture sensor with wrong data
The URL doesn't work.
Could it be the sensor has been damaged?
So maybe water can get more close to the capacitive part of the sensor?
The way I think these sensors work, then distance to the (wet) soil is key to the measured value.
Here is a new url: https://go.twenga.de/to?s=5338647&gap=1 ... gIRivD_BwE
But the sensor works quite well if i test it in a dry and totally wet environment. Today for example the values are totally normal. But some days the values are getting crazy
I made the same experience with that sensor and also with ADS1115. Works perfectly in rooms, but when installing outdoor I could not get any reliable datas. Really a pity! Maybe temperature and air humidity is responsible for this.
Users browsing this forum: No registered users and 80 guests
