hi,
when i hotplug my ds18b20 Temp sensor, the esp reboots.
Can i make it hot plugable?
hotplug i2C devices
Re: hotplug i2C devices
The DS18b20 is 1wire, not I2C.
And the Dallas plugin even does cause reboots when it is not properly connected, so I guess hot swap is out of the question for that one.
None of the plugins is written with hot plugging in mind, so it may work, but I would not advice to do so.
Also, keep in mind that hot swapping a powered sensor must use a compatible connector. For example, a TRS phone plug like this can be problematic:
Depending on plug pin-out, connectors like it may briefly short power during plug insertion. That's rarely a good thing to do.
tnx,
looks like i have to stop hotpluggin it^^
Users browsing this forum: No registered users and 138 guests
