Is it possible to use LCDs with ST7735&ST7739 controllers??
JohnW
#1 Post by JohnW » 17 Nov 2019, 09:25
Is it possible to use LCDs with ST7735 or ST7739 with ESP Easy? I have several of them: some with I2C, some with SPI.
dieter114
Re: Is it possible to use LCDs with ST7735&ST7739 controllers??
#2 Post by dieter114 » 18 May 2020, 16:54
Hi John,
i wrote a driver for a ST7735 Controller.
You can see it here: https://forum.fhem.de/index.php/topic,1 ... 9.html#new
this is a Forum in german.
Please write if y intrested in it.
Greetings Wolfdieter
Ostoja
#3 Post by Ostoja » 10 Aug 2020, 06:53
Good day! I still couldn't find your driver on the forum.
#4 Post by Ath » 10 Aug 2020, 10:42
Ostoja wrote: 10 Aug 2020, 06:53 Good day! I still couldn't find your driver on the forum.
I hope to start a plugin (or extend an existing one) for ST7735 (128x128px/128x160px/80x160px) soon (a.o. waiting for hardware from Ali), and I'll investigate if ST7789 (240x240px/320x240px) can also be supported (but often that last resolution is driven by ILI9341 -> Plugin P095).
Edit: ST7739 either doesn't exist or is a display panel only (45 pin connection, won't work on any ESP without support-hardware), so I assume ST7789 is intended
Edit2: Corrected resolutions per chip.
