time relay 2 canal
time relay 2 canal
Hi at all!
I hope anybody will help me! First i have to say - i ´m a starter...
I have bought https://www.amazon.de/Relais-ESP8266-Zw ... th=1&psc=1 an thought that i can easily reinstall another software....
That for i searched and found an sample which i thought i flash it on the esp8266 and everybody will be happy.... http://esp8266-server.de/Zeitschaltuhr.html
From this point of my testing I found out that now I have an non working equipment...
So my question is: has anybody software for this hardware or can any advice me how i can run a 2 canal 2 time relay (seconds)?
Re: time relay 2 canal
You're trying to install ESP Easy or what?
yes - i will reprogram the esp.
You need to look and see if the memory is 1MB or 512kB
Ok, that's good. Then you need to have a serial adapter to program it.
Your are joking Guy..... Whats you thougt have eine at least...,.
No need for that.christianh wrote: ↑12 Jan 2020, 00:07 Your are joking Guy..... Whats you thougt have eine at least...,.
You linked to a firmware which isn't ours... What's the plan? Are you going to use ESP Easy or not?
Users browsing this forum: Google [Bot] and 116 guests
