Sonoff new board flashing
Posted: 12 Jan 2020, 18:40
Hello, since I'm new int the board and in the automation do I want to say Hello to all of you.
I have a problem with flashing the ESPEasy to the Sonoff basic - the new board (The one with the four pins 3,3V, TX, RX, GND).
I've used the ESPEasy_mega-20191208 and loaded the firmware ESP_Easy_mega-20191208_normal_ESP8285_1M.bin to the device.
All went ok, but I cant use any of the GPIO's. Some of the ones that should be working as the button relay controller, also the led controller as well I wanted to use the DHT22 to get the temperature. None of them works as it's described in tutorials in internet.
Does anyone knows which firmware should I put to the Sonoff and which GPIO are responsable for wchich elements?
Best regards
Best regards
