SHT3x - no readings
amiable
SHT3x - no readings
#1 Post by amiable » 20 Jan 2020, 15:36
Hi, I'm on D1 mini with ESPeasy
Build 20104 - Mega
GIt Build: mega-20191208
Filename: ESP_Easy_mega-20191208_test_ESP8266_4M1M_VCC
There is a SHT30 connected to my D1 mini:
Unfortunately, I have never been able to get readings from it.
I'm newbie to ESP and not sure if I connected sensor to D1 correctly.
My connection is:
VIN -> 3.3V power adapter
GND - > ground power adapter
SCL -> GPIO-5
SDA -> GPIO-4
I will be grateful for any advice.
My configuration:
Re: SHT3x - no readings
#2 Post by grovkillen » 20 Jan 2020, 16:26
Does the i2c scanner (found under tools) show the sensor?
amiable
#3 Post by amiable » 20 Jan 2020, 16:30
No I2C devices found.
#4 Post by grovkillen » 20 Jan 2020, 18:11
Then it's up to you to find any hardware errors...?
amiable
#5 Post by amiable » 20 Jan 2020, 20:55
Thanks for the reply.
My fault: it was cold joint on SDA connector :oops: . I noticed only when I used the magnifying glass. I corrected the soldering and now everything works perfectly.
#6 Post by grovkillen » 20 Jan 2020, 21:37
amiable wrote:
20 Jan 2020, 20:55
Great! ;)
manubis_sanchez
#7 Post by manubis_sanchez » 30 Mar 2020, 15:18
Can I ask where do you get the version of ESPeasy with SHT30, please ? Or must I create a new post ?
Manubis
#8 Post by TD-er » 30 Mar 2020, 16:28
As you can see here: https://espeasy.readthedocs.io/en/lates ... al-plugins
it is included in the "testing" binary of the nightly builds.
manubis_sanchez
#9 Post by manubis_sanchez » 30 Mar 2020, 17:02
Thanks ! (I forgot there were test firmware in the bin folder :/)
I'm going to test that !
