ESP32 Lolin
ESP32 Lolin
Hello!
please tell me, I can’t understand how to flash esp32 to the latest firmware ESPEasy_mega-20200222
but i can flashing ESPEasy32_R20100-and it's ok,
what should i do to flash ?
I also tried to flash through flash_download_tools
indicating memory address 0x00 but not worked.
Did anyone flash esp32 ?
Re: ESP32 Lolin
Flashing ESP32 may indeed need some attention.
You also need some bin files for the regions before the actual sketch.
I don't have the files + screenshot at hand here, maybe someone else has?
Re: ESP32 Lolin
wath i needed files ?
the firmware ESP_Easy_mega-20200222_test_ESP32_4M316k.bin is't include ?:
boot_app0.bin
bootloader.bin
ESPEasy.ino.partitions.bin
boot_app0.bin
bootloader.bin
Re: ESP32 Lolin
It seems so indeed.
I have seen several reports of users not being able to flash ESP32 using the nightly builds.
I myself always flash it directly from the IDE, so then the other files are included in the flash procedure.
Like I said, I really need to give the ESP32 some more attention, but there are only 24h in a day...
Re: ESP32 Lolin
Hi guys i'm new here and would like to give a little bit input from my side.
I was able to to fash ESP-Easys mege with these steps:
1. only if you hav a fresh one with factory firmware installed, erase the flash with esptool.
2. an one time i have to flas the flashed bootloader and partition2 and boot_app0.bin
esptool.exe --chip esp32 --port COM6 --baud 256000 --before default_reset --after hard_reset erase_flash
esptool.exe --chip esp32 --port COM6 --baud 256000 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0x8000 partitions2.bin 0xe000 boot_app0.bin 0x1000 bootloader.bin
3. then flash the firmware
esptool.exe --chip esp32 --port COM6 --baud 256000 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0x10000 ESP_Easy_mega-20191208_test_ESP32_4M316k.bin
later i was abele to update the firmware only with
esptool.exe --chip esp32 --port COM6 --baud 256000 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0x10000 ESP_Easy_mega-20200305_test_ESP32_4M316k.bin
one hint: start the flashtool then hit the boot button on esp32. The esptool is not the one came with ESP-Easy this does not work with ESP32 (i don't kow why). I found esptool.exe version of the esptool.py. i use this because i don't have installed python. But i think esptool.py should also work.
one thing i noticed is that the buildin LED is not working as a WIFI Status LED (GIO2). I can manually switch it on an off. But it is not working like the ESP8266 devices.
cheers
cheers
Re: ESP32 Lolin
Can you make 2 issues of this post on Github?gefahrensucher wrote: ↑09 Mar 2020, 11:10 Hi guys i'm new here and would like to give a little bit input from my side.
cheers
One with the needed steps for flashing the ESP32, so we can add that to the documentation.
And one for the last line you reported regarding the status LED.
I will never find it again if it is hidden here in a forum post.
Re: ESP32 Lolin
As requested i created 2 issues at github
#2940
#2941
cheers
#2940
#2941
cheers
Re: ESP32 Lolin
I just try to flash a lolin32 with the newest firmware.
I try this way and it works: https://www.letscontrolit.com/forum/vie ... php?t=6354
I use the last update of the "espressif download tool" : https://www.espressif.com/sites/default ... v3.6.8.zip
I use the 3 first files post by "epost" : https://www.letscontrolit.com/forum/vie ... 354#p35434
and the last binary in the release package for the 4 field: https://github.com/letscontrolit/ESPEasy/releases
Like : ESP_Easy_mega-20200328_test_ESP32_4M316k.bin or ESP_Easy_mega-20200328_custom_ESP32_4M316k
On my side when I use the file included in the 20100 release package : http://www.letscontrolit.com/downloads/ ... R20100.zip it doesn't works.
But with the "epost" files partitions2.bin instead of ESPEasy.ino.partitions in particular, it works.
At this point I've some question for succeed to build ESPEasy sources in PlatformIO and include the servo motor library in, but I'll post a question in the forum about this after some research.
https://www.letscontrolit.com/forum/vie ... f=6&t=7598
Users browsing this forum: No registered users and 108 guests
